Old 15th April 2004, 05:06 PM   #1
Question regulated supply for GC
I saw many GC projects around here but most of them with simple power supplay - just a recitfers + cap. why not use regulated supply ?
Old 15th April 2004, 08:57 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Look closer and you will see that R!sc has used a regulated supply based on an idea by Pedja Rogic. I am currrently building the same design.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 15th April 2004, 09:17 PM   #3
hi Nuuk !
it was the trigger for my question ... why don't we see more like this ? simply because it's more complicated ?
yuval
Old 15th April 2004, 09:19 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
yuval, why would you need a regulated power supply? I think you should ask yourself this first?
Have in mind that the LM3875, 3886 have very good (above average) PSRR!
/Per-Anders (my first name) or P-A as my friends call me
Old 15th April 2004, 09:22 PM   #5
I really don't know but let's say I want to maximize potential of this design ?
Old 15th April 2004, 10:37 PM   #6
jackinnj's Avatar
the first simple reason is that you are burning some power in the pass element, whether it is a MOSFET or a Bipolar transistor it is going to burn (watts in the atmosphere) the energy represented by the difference between the supply voltage and the regulated voltage, plus ... why burn watts when you can turn them into SPL's.
Secondly, any regulated supply relies on feedback from a voltage or current sensing circuit to an error amplifier which drives the base or gate of the pass transistor -- thus you have to contend with the compensation of the feedback loop, timing considerations, noise of the error amplifier --
now, if you happen to pick up a couple of Lambda 28 volt, 5 amp supplies I would not dissuade you from using them (2) to drive the LM3875 or LM3886.
Old 16th April 2004, 02:04 AM   #7
jackinnj's Avatar
Default like this
a nice hefty lambda regulated supply on EB
Old 16th April 2004, 02:26 AM   #8
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
why not build a (digital) class d amp then?
how efficient are these chip amps anyway?
Si fractum non sit, noli id reficere!
Old 16th April 2004, 08:20 AM   #9
Nuuk's Avatar
it was the trigger for my question ... why don't we see more like this ? simply because it's more complicated?
If I am not misquoting Pedja here, one of the advantages of using a regulated supply is to be able to use more capacitance without the detrimental effects that has on a Gainclone with a standard PSU.
But YES, it is more complicated (remember simplicity of design is one of the big attractions of the GC) and more expensive unless you have some biggish PSU caps/spare stransformers lying around (which I did have fortunately).
If you go for a separate supply for each channel then it also becomes an exercise in logistics, with all the extra connections to the amp (I am also having to 'feed' my opamp buffers with separate supplies too).
So why am I doing it? Well like Yuval says, it is the age-old reason for doing most things in DIY hi-fi: that is to try and maximise the performance of whatever it is that you are playing your music through.
I have the greatest respect for Pedja, it was his work on buffers (as well as Joe Rassmussen) that encouraged me to build a buffered GC and that has payed large dividends. Pedja says that he prefers the sound of the regulated supply and that is a good enough reason for me to try although having the transformers and caps form my Arcam A60 amps is a big bonus so the outlay for me is not such a gamble!
Old 16th April 2004, 09:06 AM   #10
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Nuuk, I think you will eventually outbuild everyone in terms of the sheer amount of (high quality) stuff that you seem to get done
3 Pin regulated supply VS zener based supply KevinLee Solid State 3 15th September 2008 02:40 PM
Regulated power supply crissty Chip Amps 23 2nd September 2005 04:18 AM
regulated supply +- 28V -20A sss Power Supplies 8 14th June 2005 07:30 AM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
regulated 5V DC supply Tomatito Tubes / Valves 50 4th February 2003 08:33 PM
Page generated in 0.11664 seconds (85.20% PHP - 14.80% MySQL) with 11 queries
