Old 14th April 2004, 01:38 AM   #1
Adam M. is offline Adam M.  United States
Default Simple Input Buffer
Does anyone have thoughts on a SIMPLE input buffer, like one that involves an op amp, an input wire, a feedback wire and an output wire? (Well, not that simple, but you get the idea, I don't want a 10 component buffer). I posted this in the bottom of a thread below, but the more I think about it the more it belongs in its own thread.
the OPA627 was suggested, and the spec sheet looks like it can be used with no external parts, but that doesn't seem right in a practical application, but ok from a theoretical standpoint.
As a side note, I have read a few commercial products that rave about using Burr Brown amps, which I found out were TI products. Anyone use these as buffers, and if so does anyone have a suggestion to which chip?
Thanks,
Adam
Old 14th April 2004, 02:01 AM   #2
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
buf634 ? nice buffer but it somewhat degrades sound quality when used outside of an opamp;s feedback loop (imho).
/matti
Si fractum non sit, noli id reficere!
Old 14th April 2004, 01:55 PM   #3
macboy is offline macboy  Canada
The OPA627 would work fine. So would the OPA132, OPA134, OPA604, or their dual versions (OPA2132, -2134, -2604), or any other high quality opamp that is stable at unity gain. All that you need to do is tie the output pin to the -input pin, and put the input signal onto the +input pin. This creates a "voltage follower" configuration, where the output voltage is equal to the input voltage. Now you can set the input impedance as high as you want (within reason; note that higher impedance will mean higher noise) and drive the chipamp with a low input impedance. Just make sure that the opamp you choose can drive the impedance you choose for your chipamp's input impedance (most will drive 600 ohms or higher). Make sure to decouple your opamps with a small capacitor connected very close to the opamp.
Old 14th April 2004, 02:17 PM   #4
GregGC is offline GregGC  Canada
I hope you don't want to connect the buffer in front of a NIGC.
/Greg
Old 14th April 2004, 02:30 PM   #5
Just a question that nobody seems to have raised yet when using an inverting gainclone: what about the absolute phase the music was originally recorded at? With an IGC we are listening to inverted version of it.
There has been lots of discussions on whether keeping original phase is important or not for the music experience.
So why not trying a basic inverter here? We would have a buffer and also get phase back to normal.
Has anyone tried that? Pros and cons in that path?
One con I can think of is how would I use a BUF634 inside the feedback ring on a basic inverter.
Carlos
Old 14th April 2004, 02:49 PM   #6
Carlos
To solve the problem with the IGC you just have to connect the two speakers in revers (- of the speeker to the output of the amp and the + of the speaker to GND).
/Greg
Old 14th April 2004, 03:36 PM   #7
Account Disabled
wouldn't an emitter follower be a simple and effective solution here? I posted a simple (one transistor, 6 resistor and 2 caps) pre-amp circuit on the solid state forum and it can be easily set up as a follower and it works unmodified with a lot of transistors / rail voltages.
to me, that would beat out an IC buffer.
Old 14th April 2004, 08:18 PM   #8
This is all thinking right now, but somewhere down the road, it'll be in front of a parallel lm3886 or a bridge/parallel config with the same chips. How are the buffers that National specs for the BPA200, the LF411?
Thanks,
Adam
Old 17th April 2004, 07:59 AM   #9
PMA is offline PMA  Europe
PMA's Avatar
Carlos
Carlos,
I have checked invereted polarity vs. correct polarity many times. There is a considerable audible difference. For example - bass is lazy and worse defined, when inverting the phase.
I would always recommend to keep the correct phase.
Pavel
Old 17th April 2004, 10:09 AM   #10
Hybrid fourdoor's Avatar
In regards to buffer to amp, which resistor method would be best here?
I enjoy my organic shapes.....
Simple Volume/Buffer! amplifierguru Solid State 37 6th September 2010 06:41 PM
Simple Low Distortion JFET Buffer wrenchone Solid State 21 29th January 2007 08:16 PM
connecting input directly to ucd, no input buffer mazurek Class D 20 19th July 2006 03:32 PM
What is better -> Buffer or simple pre azamkita Chip Amps 11 17th March 2005 02:03 AM
simple line buffer fscarpa58 Tubes / Valves 14 9th December 2003 08:30 AM
Page generated in 0.12471 seconds (73.79% PHP - 26.21% MySQL) with 11 queries
