An open source layout for the lm3886 ?
Old 27th April 2018, 12:57 PM   #11
00940 is offline 00940  Belgium
00940's Avatar
Ok, first revision.
Now with a signal groundplane on top and a complete power groundplane on bottom. The input filter is also closer to the input gnd.
All that is excessive is insignificant. Talleyrand
Old 28th April 2018, 01:06 AM   #12
bozoc is offline bozoc  Croatia
Like the last layout, I would still try to put that C6 more to the right side (if you plan to use nichicon muse).
Old 28th April 2018, 05:32 AM   #13
Mark Whitney is online now Mark Whitney  Netherlands
Mark Whitney's Avatar
Remove the PGND plane from under the input and feedback traces/parts. The AGND plane goes under the input and feedback circuits only.
Add the option of a Hum Breaking Resistor between the output GND and AGND. This will
help when you use multiple boards connected to a single transformer.
The LM3886 inputs are high impedance, keeping these traces short will prevent hum.
Regards Mark.
Old 28th April 2018, 09:13 AM   #14
00940's Avatar
- shorter input tracks are possible if I move the RF filter before the input cap. I'll have a try.
- a ground breaker resistor... I can add that.
- removing the power ground plane around the inverting pin could help. If I'm removing it all around the input, we're pretty much back to the first layout and we're wasting some copper.
Old 28th April 2018, 09:26 AM   #15
I might be mistaken but given the LM3886, removing the PGND under feedback network might do more harm than good.
Old 28th April 2018, 09:32 AM   #16
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You can save a couple of dollars if you replace screw terminals with 1mm pcb pins.
A soldered joint is better than a terminal block.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 28th April 2018, 09:46 AM   #17
Multi strand soldered wire is prone to breakage and is not a very reliable way to connect the wire to PCB, there needs to be a strain relief of some sorts or hot glue/silicone acting as a support and that is a mess.
Terminals and crimped connectors are much more reliable over time.
Old 28th April 2018, 10:02 AM   #18
cspirou is offline cspirou  United States
BTW, BrianGT of chipamp.com has open up his boards to the public domain.
my first try at a LM3886 layout, any comments/suggestions?
Old 28th April 2018, 10:37 AM   #19
levistubby is offline levistubby  United Kingdom
There should be no need for strain relief in situations where the cables don't move. Unless of course the cable are very heavy, which will not be the case here.
Old 28th April 2018, 11:58 AM   #20
00940's Avatar
Nothing prevents someone to solder wires directly in the holes made for screw and faston terminals.
As for the chipamp PCB... Well, it's missing most of the stability components and it's not a particularly good layout imo.
For the ground plane under the feedback network. Usually, the problem is capacitive coupling at the inverting pin. But considering the length of the legs of the IC, it's probably not a big deal here, as it can be with fast opamps.
An open source layout for the lm3886 ?Hide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 02:31 PM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 03:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 02:21 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 10:35 PM
