Not Your Mommy's GC
Not Your Mommy's GC
Old 13th April 2004, 08:08 PM   #21
lgreen is offline lgreen  United States
lgreen's Avatar
Default dd gallery
Nuuk, and anyone else who has GC galleries, if you think this is worthy, feel free to post my pics in your gallery (full version and more pics are on my temporary web site linked in this thread and "www" below). Just send me an email so I know. My pics take time to load due to slow web server, just hit "refresh" to get them all.
Old 13th April 2004, 10:28 PM   #22
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Certainly worthy! I'll pop it in when I get time.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 14th April 2004, 03:01 AM   #23
soundNERD is offline soundNERD  United States
nice work, actually, excellent.
i have never seen such an amazing looking first project!! i think you might be the next Peter Daniel.
keep up the good work!
i like the LEDs. i dont get all this noise stuff, its not like you'd notice it with a 3886 or most speakers.
-mike
Old 14th April 2004, 04:28 AM   #24
AJ Bertelson is offline AJ Bertelson  United States
Send a message via AIM to AJ Bertelson
are those the heatsinks that were posted for sale on electric goldmine about a month ago?
Old 14th April 2004, 04:42 PM   #25
lgreen's Avatar
Default Responses
Yes, I have used those heat sinks. I have actually been telling everyone here about the heat sinks and WBT RCA connectors (both of which you see on my GC) from Electronic Goldmine for a while, even back when they (the heat sinks) were not even discounted as much as they are now. I was so new to this forum I didn't even know if this was proper behavior. See:
http://www.diyaudio.com/forums/showt...774#post302774
http://www.diyaudio.com/forums/showt...577#post292577
http://www.diyaudio.com/forums/showt...069#post245069
http://www.diyaudio.com/forums/showt...765&highlight=
I note that they do ring somewhat when dinged with your finger. So dampening is somthing you might want to conisder. I've tried felt pads underneath, but interwoven rubber bands seem to work the best. Whether or how it affects the sound I am not so sure of yet. I like a sharp HF response, so maybe it doesn't bug me.
Old 14th April 2004, 06:43 PM   #26
Nuuk's Avatar
Full story
here.
Old 22nd June 2004, 01:36 PM   #27
cpemma is offline cpemma  United Kingdom
Originally posted by Nuuk
I was always lead to believe that LED's were noisy items best kept away from hi-fi, even to the point of removing them from the mains distribution strips.
One possible source for the bad LED publicity...
I've a NAD CD-player and one thing I remember from reviews around the time is that NAD said they'd used an LCD for the info panel rather than the usual LED panel to reduce noise from the rapid multiplex switching of segments carrying several mA each.
However, an indicator led on steady current is a totally different kettle of fish.
Old 22nd June 2004, 01:57 PM   #28
arniel is offline arniel
I seem to recall reading that NEON indicators generate noise on the supply lines...
Arnie
Old 23rd June 2004, 06:36 PM   #29
Doovieman is offline Doovieman  United States
Default Heatsinks and case
Very nice work. I like the look. I was wondering if the inside of the amp gets hot. I didn't see any slits in the top of the case for the warm air to escape. Are they not needed or did you come up with a cleverl solution to let the warm air dissipate? Thanks,
Doovieman
Old 24th June 2004, 05:12 PM   #30
lgreen's Avatar
Default Ventilation
OK, the heatsinks don't get very hot unless you really work the amp, but I do so I was concerned about this. I drilled some ventilation holes in the cover.
I don't know if I said this before, but I have a very very minimal set of tools.
So I created a hole pattern on the computer that would overlap the heat sinks, printed it out taped it to the cover and drilled away. Here are the results. You see that some of the powder coating on the chassis cover kind of stuck and didn't drill away. Anyway, the ventilation seems ok and I can make the holes bigger if necessary. Also, if you look at the web pages you will see that I planned for this in that one of the first things I did was to drill vent holes in the bottom of the chassis to allow for convection through the top holes when I got around to drilling those.
This ventilation is pretty good, but not great. When playing this very loudly, the sinks get hot enough to burn your hand, and the vents don't really evacuate air that quickly. I'm going to do a kind of thermal study to see what gives, but it certainly works just fine and I've had no problems with extended high volume runs.
Not Your Mommy's GCHide this!Advertise here!
Not Your Mommy's BOSOZ - Finished lgreen Pass Labs 21 26th December 2004 11:25 PM
Copyright ©1999-2017 diyAudio
