| Chip Amps Amplifiers based on integrated circuits |
I was looking at the an-1192 application note and was thinking about how to implement a volume control on the parallel config. There is a 47k resistor from the input to ground, and any volume control put in front of it will have at least some of volume control resistance in parallel with the 47k resistor, decreasing the resistance to ground. Is this a problem? I'm just trying to conceptualize how this will work. THanks for any suggestions.
-Adam |
#2 |
Probably a buffer would be best bet.
Adjust the signal going into an opamp (NE5532 type), then the opamp signal goes to the main amp. You can get NE5532's, or OPA627's and UA7912/UA7812's from TI through samples, so your only out a couple resistors and caps.
I enjoy my organic shapes..... |
#3 |
Looking at the spec sheet for the OPA627 it looks like that if using it as a buffer it can just be hooked up as a non-inverting amp connecting the output back to the negative input, but that gives a gain of 2...
Is that typically acceptable for an input buffer, or would it be better to run it inverting so the gain would be 1? Where to the resistors and caps come in building a buffer? In school I saw a lot of math, and not a lot of practical apps. THanks for the help. |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| PC volume control | sumacSK | Chip Amps | 9 | 28th November 2005 05:33 AM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
