Old 11th April 2004, 06:55 PM   #1
Default Gainclone
Has anyone tried using gainclone chips LM3875/2875 to drive small inductive loads? I'm thinking using one to drive a small 30VA toroid transformer in a power regeneration project.
ckt
Old 12th April 2004, 09:53 AM   #2
adx is offline adx  New Zealand
I've done similar things. It should work well, an inductive load is a naturally easy load for an amplifier chip. The chips are overcurrent and overtemperature limited so they are reasonably robust.
A couple of caveats:
I ran into HF oscillation problems - normal GC precautions (Zobels, not running at low gain, short FB path etc) should see it work well.
Watch out for the low DC resistance of the transformer. Even a small offset voltage will cause a reasonable DC current to flow, and toroids saturate very easily. Some way of tweaking out the offset might help (see National appnotes).
When driving low impedance loads, what is the killer? - Prevention? CBRworm Solid State 25 6th April 2009 01:09 PM
Behringer DEQ ok driving multiple loads brucemck2 Subwoofers 0 18th January 2006 09:49 PM
Driving Low Impedance Loads weinstro Solid State 14 8th May 2005 09:53 PM
Zen driving high impedance loads supa-roo Pass Labs 2 18th April 2003 07:23 PM
Best amp choice for driving NASTY speaker loads stokessd Pass Labs 8 25th March 2003 11:32 PM
Page generated in 0.07142 seconds (63.87% PHP - 36.13% MySQL) with 10 queries
