Hello Everyone, great forum. I am getting interested in building my own chip amp.
Can the LM4766 drive a 4-ohm load? All the documentation states 8-ohms - but I can not find a tolerance or minimum.
Has anyone done a LM4766 design with a single power supply? I think building a 40W x 4 amp for an DSP speaker project and it would be nice to have one 18V x 18V transformer driving two 40Wx2 LM4766 (or similar) chips.
Thanks for the input.
Link to datasheet: http://www.ti.com/lit/ds/symlink/lm4766.pdf
...Can the LM4766 drive a 4-ohm load? All the documentation states 8-ohms...
Did you read the sheet you linked?
Page 6 shows single-supply connection.
Page 6 also shows a Bridged connection apparently driving 8 Ohms, which is a 4 Ohm load on each amplifier channel.
However figures 17 and 18 on page 10 shows what you ask: output for various loads. At +/-30V the power peaks at 6 Ohms and is way-way down at 4 Ohms, due to both overheating and the 3-4A limit that abraxalito refers to.
Thank you PPR. First of all, how is Maine these days? I just spent a week in Eustis while skiing at Sugarloaf - but I degrees.
Yup, saw that and that is what gave me the idea to ask if anyone has attempted this before.
Thank you PRR. I was not sure If I could make that leap that a bridged channel driving 8-ohm could have two channels driving 4-ohms.
I did miss this graph. You are correct, it drops like a rock below 6-ohms.
