Hi guys!
just for fun and in order to learn (I'm still a newbie!) I would buy this vintage amp module kit (please see the picture below)
It's very...very cheap, because is a new old stock.
Is it easy to assemble, in your opinion?...the things that worry me mostly are the two trimmers on the circuit board: i mean their setting.It's the first time for me, but I love so much this vintage DIY amp kit!
What do you think?...Do I give it a chance?
Please guys give me your opinion!
Thank you very much
Thank you very much
It is a simple, discrete stereo amplifier with a single potentiometer (per channel) for adjustment (probably bias current or offset voltage). It should be fairly easy to assemble but you need a multimeter to do the adjustment (with the potentiometer).
If it is that cheap, give it a chance. DIY involves running a small risk that the project will fail, but we learn all the time.
Have fun.
Have fun.
NB: This is simplest and cheapest kit I have ever assembled
1 set TDA7297 VERSTERKERPRINT onderdelen dc 12 v grade 2.0 dual audio encoding 15 w elektronische diy kit B52 in 1 set TDA7297 VERSTERKERPRINT onderdelen dc 12 v grade 2.0 dual audio encoding 15 w elektronische diy kit B52 van Geintegreerde Schakelingen op AliExpress.com | Alibaba Groep
It worked well, needed no adjustments but I had to add a small aluminum plate at the rear of the TDA7297 chip for cooling.
The MoFo would be a good option as well. There's a whole thread about it in the Pass subsection.
The kit shown in Post #1 should work well enough, though. I wouldn't expect HiFi quality, but rather a good learning experience. As suggested above, the electrolytic caps may have dried out and should probably be replaced. Then again, they might not have.
One of the many LM3886-based amps could provide the same learning experience and possibly better sound too. It'll be less plug-n-play in most cases, though.
Tom
Tom
Thank you Nigel!...but what about my question (power supply type)?:confuso:
The instructions should tell you what power supply you need.
Or download chip datasheet to find out max voltages.
Does it need a normal (+/-) power supply or a symmetrical one ( I mean +0-)?
I'd guess from looking at the pcb that's it's a single supply circuit.
Good luck, post here how it turns out.
- Chip Amps
- a vintage DIY amp kit:is it simple or not?please look!
