Old 10th April 2004, 07:46 PM   #1
Default still few PSU questions...
hi,
I didn't find the answer with search but it was not easy to cover everything...
1) has anyone compered dual mono version of GC against one TX version ? what was the difference in sound ?
2) I need 30-40W power to drive 88db/6 ohm (~3 ohm min. ) speakers - SF concerto home. what TX should I use ?
3) still not sure how to build a PSU for monoblock - one rect. ? or two ?
is this http://home.student.utwente.nl/f.s.b...rtedLM3875.gif how you do it ?
thanks in advance,
yuval
Old 10th April 2004, 08:30 PM   #2
analog_sa's Avatar
1) Strangely enough i prefer the single tramsformer. It sounds more coherent and musical to me. Apparently this involves grounding compromises but even so i prefer it.
2) Driving SF Signum i find that 350VA (2x34vdc) shared between two channels is about the minimum acceptable.
3) Two rectifiers sounds better than one to me. Using two separate transformers with the primaries in series a la Kuei sounds even better. So does the dc blocking circiut.
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
PSU for QSC amp questions rkc7 Parts 5 10th November 2005 05:18 PM
Last questions about this Madmike2 Multi-Way 9 13th June 2005 11:12 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
Page generated in 0.07736 seconds (65.05% PHP - 34.95% MySQL) with 10 queries
