| Chip Amps Amplifiers based on integrated circuits |
Where do you guys connect the NC-pins on th LM4780? Should I leave then un-connected or could I use them to optimise the power-routing on the PCB? It is possible to route wider tracks or add bigger copper-planes when using the NC-pins as "passive-power-pins". Bad idea?
#2 |
diyAudio Retiree
NC stands for No Connect. Here in Rio Linda that means not to connect them to anything.............
#3 |
I agree with Fred, chop 'em off!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
diyAudio Retiree
Man! I thought I had been moderated over waffles for a sec there.....
#5 | |
#6 |
I get the message.
#7 |
diyAudio Moderator Emeritus
I would prefer to not clip the pins off of the chip, and leave them on to offer the chip better support, with respect to the connection from the pcb to the chip.
Then, on the pcb layout, the pins are simply not tied to anything. This worked out quite well on my LM3875 layout. The chip sits much better with all the pins attached. Another issue, is that the pins on the LM4780 are so small, and I would be afraid that I would cut off too many, or the wrong ones. I bought a few from Digikey, and am going to try to make an amp with them in the future. -- Brian |
#8 |
Maybe I can check for ESD diodes first. In most cases there would be some kind of ESD protection between the supplies and in- or-output-pins. If there is an open circuit that would mean the pin is not a TP.
I too prefer to keep all the pins attached. In some cases the stress from cutting off some pins is too much for the leadframe and can damage bond-wires of neigbouring pins. Atleast that's yhe case with smaller packages. I don't have any experiance with this type of package but I will not risk it. Also the comment about stability is very true. ...yeah we do have tasty waffles here in Belgium.....ever tried some real Belgiun "frieten"? (The best French fries are not French )
#9 | |
I was in Belgium a couple of summers ago, and I did have some French Fries and Waffles, and they were quite good. -- Brian |
#10 |
I second Fred's advice.
The manufacturers should even call them DNC: Do Not Connect! A friend of mine built a TDA7294 amp last week, and on the fisrt channel he tied the NC pins to ground. The chip exploded at the first powerup PS: and the best fries are french
| Collets for 212 pins | mobyd | Tubes / Valves | 4 | 13th May 2010 09:23 PM |
| Connector, where can I get pins for it? | AdamB | Parts | 6 | 14th March 2006 03:13 PM |
| LM4780 no connection pins | G.L. Tirebiter | Chip Amps | 5 | 31st March 2005 09:28 AM |
| crystal with three pins.. | Marlowe | Digital Source | 4 | 16th January 2004 03:50 PM |
| lm pins | theChris | Chip Amps | 0 | 26th April 2003 10:32 PM |
| Page generated in 0.10586 seconds (74.02% PHP - 25.98% MySQL) with 11 queries |
