Old 9th April 2004, 09:38 AM   #1
Arrow Velleman K2572 Preamp
I have a Vortex 2 sound card in my computer which have a quite low line out level. When I connect it to my home audio system I have to turn up the volume quite a lot, getting a noisy signal as result. Also when I change source to my cd-player forgetting lowering the volume my loudspeakers are about to explode.
I therefore bought the Velleman K2572 preamp kit intended for "low noise, audio/hifi stereo use". I take the power supply directly from my computers 12V wires. BUT I get a very noisy signal with a hum. I use very short wires from the sound card except for the power cables. The quality of the soud is also very bad, no low tones are amplified. (The frequency of the preamp is 40Hz-30kHz, should't that be enough?) The power seems very stable at 12.21-12.23 V. Is it impossible to use such pre-amplifier near the computer or what is the problem?
/Erik
Old 9th April 2004, 09:52 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I don't know how well the chip of your preamp rejects power supply noise...
But I think that the power supply from the computer is of the switching type...good enough for a computer... but not for an audio preamp..
However I don't think that is your problem...why not try the preamp in your home setup first. If you don't have the problem in your audio system...it might be because of the noise inside the computer and / or the psu.
In other words try to isolate your problem by taking the preamp somewhere else and / or using a different psu...
Bas
Old 9th April 2004, 10:41 AM   #3
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
computers power supply got only one rail of 12V
can your pre amp work with single supply?
Old 9th April 2004, 10:48 AM   #4
Well, I don't know, I just use one of the wires which isn't in use (on the power chain for 3,5" IDE units). I measure the voltage to 12.21-12.23 V. I think +/-0,01 V should be enough...?
Old 9th April 2004, 10:51 AM   #5
Frank Berry's Avatar
The output coupling capacitors (there are 2 of them in each channel, one before the level control and one after the level control) are rated at 1 ufd. You can improve the bass response by increasing their values to, perhaps 4.7 ufd.
Frank
Old 9th April 2004, 10:53 AM   #6
You might try operating the preamp from a pair of series-connected 9 volt batteries to see if the hum goes away.
Frank
Old 9th April 2004, 11:44 AM   #7
Thank you for suggestions! Maybe i get rid of the hum, but not the noise i think. To me it seems that the Velleman K2570 is crap. Maybe it's easier to buy another sound card. Does any know of of soundcard with higer output level? The ideal would be a soundcard with hardware adjustable level.
I have also tried to gain the level in software with the Winamp preamp but the sound become crappy. And none of the problems has to do with my stereo or wires because I listen to the source directly with earphones.
/Erik
Old 9th April 2004, 08:01 PM   #8
rho is offline rho  Belgium
Looking at a picture of that pre-amp module it is just a 8pin DIP dual opamp with a trim-pot at the input.
What type of opamp do they use? What is the value of the caps by-passing the supply? they could be closer to the opamp in my oppinion. They also use plain electrolites for inout caps.
An other thing I'm afraid of is that there is some feed-trough from the switching power-supply of the computer, to the pre-amp board. Ddi you use shielded cables for the audio-signals?
Old 9th April 2004, 08:57 PM   #9
neutron7's Avatar
most of the noise is probably from d/a converter and related circuitry on the sound card before the amplifier stage.
so if you amplify it with anything else the noise will still be there.
you might be better off getting a different sound card instead.
m-audio soundcards have lower noise than most soundbl***s
http://www.m-audio.com/index.php?do=...a955aa6ae2db1c
that is their consumer offering. I used one to replace the on-board sound on my shuttle PC and the sound is much much better and quieter(noise wise).
I think the output level must be higher as well becuase the shuttle is connected to my mixer via a very long cable and it used to be quite bad. this one seems to drive it a lot better.
this one looks good too
http://www.m-audio.com/index.php?do=...3fa8b83343bfb8
Old 10th April 2004, 06:54 PM   #10
I didn't use sheilded cables, because the cables from the sound card to the preamp are less than one inch long. And the noise is not from the D/A converter because the sound directly from the sound card doesn't have much noise. I think the combination of bad power supply (even it seems ok with my multimeter, which isn't probably fast enough) and a low cost preamp is the problem.....
I have to admit, I not really that fanatic, and don't know of "opamp" and such things but thanks anyhow!
/Erik
Velleman K8020 Tube Preamp Algar_emi Tubes / Valves 10 4th March 2012 11:32 AM
Velleman K4040 Brap Tubes / Valves 17 20th October 2011 09:56 PM
velleman K8060 Harry Fisher Solid State 7 7th August 2009 02:31 PM
Velleman K4010 george88 Solid State 5 10th July 2004 11:52 AM
Velleman HPS-10 Oscillioscope newbie1 Parts 0 6th January 2004 02:44 AM
Page generated in 0.13457 seconds (79.08% PHP - 20.92% MySQL) with 10 queries
