Another BPA200 post: Need some advice on finalizing design
Old 8th February 2018, 11:36 PM   #21
00940 is online now 00940  Belgium
00940's Avatar
It looks like the antek transformer would be alright, tying red and orange to make the CT. I guess the footnote is to avoid people unbalacing the transformer by using only one secondary or playing with weird configuration with the primary.
Btw, the antek transformers might come cheaper. The 400VA is 51$, the 800VA is 84$ and the 1000VA is 100$ but you have to order from them.
As a side note, I've stopped etching my own boards. The price and quality of the cheap fab houses in China is just unbeatable, especially for small boards. The only downside is the one month wait time to get the board (even worse now with the Chinese new year).
Edit: the suggestion of using the drv134 is to get a differential signal so that you can use all inverting lm3886 and not half inverting, half non inverting. The lm3886 is slightly better in inverting config.
All that is excessive is insignificant. Talleyrand
Old 8th February 2018, 11:45 PM   #22
sr2002 is offline sr2002  United States
So, would you suggest using something like ExpressPCB and then ordering through them? Any other software suggestions and places to order PCBs in the US?
Also, any recommendation on the mute circuit strategy that I had mentioned earlier?
I'll check out the Antek transformers, I think they have an ebay store too.
Old 8th February 2018, 11:52 PM   #23
tomchr is offline tomchr  Canada
tomchr's Avatar
OSH Park makes good PCBs. I hear good things about KiCAD software but have no personal experience with it. Some swear by Eagle, but last I tried to use it, the UI made me lose my mind. Maybe the company that bought it decided to make it usable. I also seem to recall some quite usable demo versions of OrCAD and Altium being offered by their respective vendors. Both OrCAD and Altium are industry standard, so if you get over the learning curve, you'll have a useful skill that could be applied in the job market should you so desire.
See Post #12.
Why bother with ePay? Just go through their website. The Antek Transformers are incredibly value for the money and John usually ships them within one business day of order placement.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 9th February 2018, 12:00 AM   #24
Tom, thanks for the info I'll check OSH out.
For mute I was referring to what I mentioned in post #17 of having individual resistors and capacitors for each IC
Old 9th February 2018, 12:05 AM   #25
tomchr's Avatar
You can combine the mute RCs as I mentioned in Post #12 or go with separate mute RCs as you described in Post #17. I'm not seeing any issues with either approach.
Tom
Old 9th February 2018, 12:07 AM   #26
I see. I was just checking Antek's website, any reason I shouldnt just go for a prebuild unregulated PS such as the PS-8N35 and then just add my Nichicon 10,000uf x 4 caps + rest of the PS circuit from the AN-1192 doc from the rectifier output.
Old 9th February 2018, 12:10 AM   #27
Nevermind actually, I dont think those are dual supplies
Old 9th February 2018, 12:22 AM   #28
00940's Avatar
Expresspcb is quite expensive and ties you to a pretty bad piece of software. They're fast and quality is ok on the other hand.
If you want an US factory, OSH park is a good compromise in between speed and cost. Quality is very good too. For small high quality boards in small quantity, it's really worth it.
If you don't mind waiting a bit longer, it's worth considering a Chinese seller, such as smart-prototyping (that's the one I'm usually using). Quality is a bit worse but that's no problem with such simple pcb.
To give you an idea, for 8 pieces of 5.5 inch square pcb (using mine as exemple), OSH Park will cost 82.5$ (for 9 pcs actually). Smart proto will make 10 pieces for less than 20$ shipped.
Software wise, I'm using Eagle myself but it's just because I started with it. I tried Kicad (much more flexible and powerful than Eagle freeware) but couldn't get used to the interface and the libraries management.
Old 9th February 2018, 02:04 AM   #29
tomchr's Avatar
Seeed Studio is another el-cheapo Chinese PCB manufacturer. I have no personal experience with them, but many here seem to like them.
If you are going to learn a piece of PCB layout software, learn one that outputs Gerber files. That's the file format used by the PCB manufacturers.
Tom
Old 9th February 2018, 03:57 AM   #30
asuslover is online now asuslover  Romania
maybe this will help : PA150 - 3x LM3886 PCB assembly guide
neurochrome.com (Tom) has a this THAT Driver instead of drv134.
Another BPA200 post: Need some advice on finalizing designHide this!Advertise here!
BPA200 LM4780 Board (Unfinished) Design Protoboard Solid State 1 9th May 2015 09:18 PM
Finalizing TDA2050, LM3886 pra3718 Chip Amps 27 14th February 2013 01:05 PM
Finalizing FR125 configuration Voodoo Rufus Full Range 32 19th June 2006 08:40 PM
BPA200 PCB design nterikun Chip Amps 1 13th September 2005 09:39 PM
Finalizing box volume for SS8565-01s, does this look about right ? Jean Multi-Way 14 3rd May 2003 03:28 AM
