More GC Power Trouble More GC Power Trouble - diyAudio
Old 8th April 2004, 12:02 AM   #1
rampage101 is offline rampage101  Australia
Send a message via ICQ to rampage101 Send a message via MSN to rampage101
Default More GC Power Trouble
Hi all,
I've almost got my Gainclone worked out, but I have several problems.
My toroid is a 18-0-18, Its got 4 secondary leads and 2 primary leads. That was all straight forward, 2 primarys to wall, 1 pair secondaries to 1 rectifier. Now, after rectification, I get the same voltage. It's supposed to go up to like 25v isn't it?
Secondly, I've had the amp working and everything of 38v, but after about 3 seconds the sound just goes distored and so I turn it off. What would cause this? The sound works fine for the first 3 seconds.
What's a signiture?
Old 8th April 2004, 01:58 AM   #2
Woot. I think I've got it now, when I've just got the 1 rectifier from 1 pair of secondaries, I get 25v under load (well when the amp is connected and turned on anyways).
So now I just need to make some nice little boards to glue all components down to and solder it all up again. Get my fuses worked out (well put some in to start with)
Any ideas what would be cause the sound to start distorting after about 3 seconds? Could it have been because I was feeding 1 chip 50v?
What's a signiture?
More GC Power TroubleHide this!Advertise here!
TubelabSE power supply trouble wicked1 Tubelab 26 14th December 2008 07:59 PM
arcam delta 290 trouble in power amp section please help homertooties Solid State 12 25th September 2008 01:26 PM
capacitor brands & power transistor trouble on hk amp mrlennon Parts 15 24th October 2005 03:37 PM
trouble with high power amp bombardon73 Solid State 13 31st July 2005 05:20 PM
GC Power Supply Trouble blackreplica Chip Amps 54 18th May 2004 03:07 PM
Copyright ©1999-2017 diyAudio
