Small helps, but the critical parameter is low LOOP AREA for every current route.
A AndrewT R.I.P. Joined 2004 2018-01-17 3:17 pm #21 2018-01-17 3:17 pm #21 Small helps, but the critical parameter is low LOOP AREA for every current route. ••• More options Share Mark Whitney Member Joined 2013 2018-01-17 6:16 pm #22 2018-01-17 6:16 pm #22 That is the reason your DC measurements are not what you should expect them to be. Connect capacitors after the diodes. Check for correct polarity. ••• More options Share Mark Whitney Member Joined 2013 2018-01-17 7:35 pm #23 2018-01-17 7:35 pm #23 This is the voltage without capacitors. ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
