LM3886 opinions sought
Old 8th January 2018, 10:51 AM   #11
R.I.P.
I like your signature line with the links to three sites I have used a lot.
regards Andrew T.
Old 8th January 2018, 12:08 PM   #12
john blackburn is offline john blackburn  United Kingdom
Decibel Dungeon was the first place I saw the word Gainclone which eventually lead me to this forum. Even the bathroom has speakers now.
Decibel Dungeonhttp://www.decdun.me.uk/ Elliot Sound Proucts ESP http://sound.whsites.net/ All About Circuits http://www.allaboutcircuits.com/education/
Old 8th January 2018, 12:46 PM   #13
bullittstang is offline bullittstang  United States
I currently run 2 inexpensive LM3886 from eBay with a 28VAC toroidal, with an iPhone as the only input. They will take full power from the iPhone with only a very rare clip (2-3 times in the last 2 months) but have to run the iPhone at 100% to get it to clip. I typically listen at 40-50% on the iPhone though and they do just fine.
I have both chips on a 7-1/2 x 2-1/4 x 2 inch finned heatsink, running in my basement (60 degrees F right now)
I am running a Mauro Penasa LM3886 with 22VAC torroidal (same size heatsink) - and it certainly sounds better, it will be up to you if $150 compared to $20 is worth the difference, just more refined in most every way.
Edit - this is running on 4-ohm DIY speakers (4-ohm woofer, 4-ohm tweeter), but the industry would probably say they are 6-ohm nominal.
Old 8th January 2018, 07:19 PM   #14
If the budget was available I would love to hear a Myref or Modulus implementation of the 3886 but I can't justify the costs as things are.
The amps I have are at the minimalist end of things. My first was a chipamp.com LM3875 which is still playing daily some 11 years later and taught me all about the invisible lacquer on transformer secondaries. That was followed by a couple of point to point builds with more of the "optional" stability components included, so I have yet to hear the best sound you can get from them.
Interesting to hear you are running on even higher voltages than I was proposing too.
Old 8th January 2018, 07:36 PM   #15
There are way smarter people on this forum than I, so I can only say that it works...not that it is the best long-term solution.
For me - $20 is not enough to warrant not using the toiroidal I already had, even if they get destroyed. I did make sure to have speaker protection, just in case.
After being a mosfet guy in all my previous amps - I was surprised and have been very happy with the LM3886 amps. Much better and stronger bass than I expected and easy to listen to. My previous Class D cheap amps always seemed to be shrill and my ears got tired of listening to them after 30-45 minutes.
Good Luck on whatever you build - sure it will sound great and give you years of entertainment.
Old 11th January 2018, 10:08 PM   #16
tomchr is offline tomchr  Canada
tomchr's Avatar
2x25VAC is a bit much for a single LM3886 as you'll get about 35-36 V DC out of it. I explain my reasoning here: LM3886 Output Power. You could choose to drop the supply voltage a bit using a 5.6 V, 5 W zener in series with each supply lead.
You could also implement a simple zener regulator with a transistor (requires four components). You'll probably want a darlington transistor as shown here - or a MOSFET. You'd want the transistor on a heat sink ... which it could share with the LM3886.
Then you get the bragging rights to having a regulated supply... Read the full circuit description here: Transistor-Zener Diode Regulator Circuits
Should you later decide to drop in a MOD286 in mono configuration for 100 W into 4 Ω, you'd have the supply and heat sink ready to go. Just remove the zener diode or regulator and drop in the MOD286.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 14th January 2018, 01:55 AM   #17
Hi Tom, sorry for the delayed reply. Thanks for the advice and links, I will have a proper read of them later when I get chance.
I have been reading your site recently, that's some grasp of maths you've got.
Old 31st January 2018, 02:56 PM   #18
A bit of an update.
Further biscuit tin rummaging turned up four LM338s that I bought years ago to try a regulated chipamp using CarlosFMs design. I didn't get round to it at the time so I think I will try those at 28 volts to start with, and maybe try discrete regulators eventually.
What are your collective thoughts on the best way and place to create a signal ground when point to pointing? I can't do it on the RCAs due to the distance.
I have used a one ohm resistor from the power ground as a signal ground point on a previous build which seemed to work nicely, so that is probably the plan unless I've missed something.
John
Old 31st January 2018, 03:44 PM   #19
R.I.P.
Placing the main audio ground reference point on the speaker output terminal is probably better for a discrete P2P assembly.
regards Andrew T.
Old 1st February 2018, 05:11 AM   #20
Nenola is offline Nenola  Finland
Do you have a picture of what they looked like? I was going through the options one day and ordered one mono board for about 5, so not a big loss if it's no good.
LM3886TF AC 20~28V 60W Sound Audio Amplifier Mono Digital Power AMP DIY Kit | eBay
I know that there are better designs out there, but I just need a mono amp that does the job decently. Need to upgrade one LM1876 from my 2.1 amp to this, so it can better drive a 4 ohm subwoofer.
LM3886 opinions soughtHide this!Advertise here!
Opinions sought from Parasound A23 users rabbitz Everything Else 2 31st August 2015 12:36 PM
New Cabinet Opinions & Advice Sought Thomo Full Range 8 30th December 2008 11:03 PM
pioneer PD91 (old ) opinions sought odeer Digital Source 1 8th January 2004 12:05 AM
Opinions sought on Heatsink rating (see photo) Nicwix Pass Labs 6 17th July 2002 10:38 PM
Tube DAC - opinions sought peted Digital Source 3 25th July 2001 08:43 PM
