An audio unit for Canon EOS 5D mk iv
Old 28th December 2017, 10:34 PM   #1
Kentil is offline Kentil  Sweden
Default An audio unit for Canon EOS 5D mk iv
When recording video and audio it is usuallay a good idea to use an extern mic and monitor the audio by earphones. In order to quickly adjust the audio level and at the same time concentrate fully on the video recording, there is a need for an external adjustment. The audio level needs to be adjusted from, lets say -10 to +20dB?
In my case I have the following facts and requests,
Facts:
-Camera canon 5D mk iv. Stereo/mono, 48kHz/16bit, Auto level and manually reduction from 0 to -40dB. No amplification.
-Röde Videomic. (mono, condensor, 40Hz-20kHz, Eq. noise level 20dB-A, sensitivity-38dB, impedance 200ohm)
-No facts on impedance and amplitude level on Canon.
Design:
-A small unit where you connect the mic and the cable to the camera.
-A volume control for each R and L channel. When only a mono mic is connected only one control should be active.
-The power supply should be maximum one 9V battery but up to four AA (recharg) is preferred.
-In order to prepare for other mic (thinking of a parabolic with higher impedance) there should be some kind of adjustment/choice of mic type. An alteration switch on the box?
-If not to complicated; some kind of filterfunction (highpass and lowpass? A mini equaliser?) to reduce any disturbing sound.
-The quality should be Hifi/professional with very low values on noise, distortion
Possible solutions:
Ifound some circuits, AD8397 and ADA4004, perhaps suitable? Didn't find any interesting applications so this is my question. Does anyone has any schematics ideas of the above application?
Thanks in advance
Kenneth
An audio unit for Canon EOS 5D mk ivHide this!Advertise here!
Streaming Audio to Head Unit via USB cukaracha Car Audio 0 5th December 2014 08:19 PM
Best Car Audio Audiophile Head Unit You Have Used And Tried Celestra-rules Car Audio 62 10th June 2014 10:41 PM
An audio test bench control unit? Terry McGee Equipment & Tools 9 11th June 2012 10:26 AM
Analog Summing Mixers by Unit Audio Unit Audio Vendor's Bazaar 0 10th June 2012 01:38 PM
WTB: DENON AVR-3300 AUDIO/DSP unit Junie Swap Meet 0 11th November 2011 03:34 AM
