| Chip Amps Amplifiers based on integrated circuits |
We can adjust the performance of the amplifier of chip through reducing the voltage , And can bring a lot of advantages.For example we choose upgrade devices,base on the premise that performance is very good, the fabrication cost will not be very high,We can supply power with the battery etc.
But the low-voltage chip circuit has deficiencies,output power will be reduced. We had once compared a soz(class-a 2x10w) and a 3886IGC (2x30w)with 8 ohm load.Feel that the output power of soz is greater. This is a high sensitivity loudspeaker that I made for 3886igc, very small and exquisite.2way closed design.use 12 bit/doc frequency division.Because I like ls3/5a,so make it into her appearance. |
#2 |
This is another one,I put inside my father's sitting room.
| Power load, dummy load (pic) | luka | Power Supplies | 43 | Yesterday 03:50 PM |
| Dynamic load line analysis using music and speaker load | Michael Koster | Tubes / Valves | 0 | 7th March 2008 09:47 PM |
| SI T-Amp 2 ohm load | edjosh23 | Class D | 2 | 21st February 2007 05:54 AM |
| 2 ohm load on T-amp | 3-LockBox | Class D | 1 | 22nd June 2006 01:38 PM |
| SOZ 4 ohm load | cjunk | Pass Labs | 7 | 14th March 2002 08:23 PM |
| Page generated in 0.06455 seconds (73.55% PHP - 26.45% MySQL) with 11 queries |
