Help me design my home music system amplifier with loudness controls.
Old 19th December 2017, 08:53 AM   #11
BasicHIFI1 is offline BasicHIFI1  Sri Lanka
Might as well order a tone control and see. May be able to get one locally.
Tone Volume Bass Treble Control Board 3-Channel Subwoofer 2.1 Amplifier DIY Kits | eBay
Old 19th December 2017, 01:51 PM   #12
Naaling is offline Naaling  Portugal
Originally Posted by BasicHIFI1 View Post
I could use an EQ, but I do not want to spend too much, it will cost much more than the amplifier board.
There are software EQs did you mean that? Some streaming music services do not have the EQ facility, and anyway have to be adjusted on the device, nice to have some physical tone controls.
If you are using Windows, you might find "equalizer apo" useful. It installs at the operating system level and can be used for anything you play. And its free.
Equalizer APO download | SourceForge.net
Peace Equalizer, UI for Equalizer APO download | SourceForge.net
Old 19th December 2017, 06:22 PM   #13
ctrlx is offline ctrlx  United Kingdom
you want a "loudness boost" function, whereby its level of "boost" is defined by the position of your volume setting?
Old 19th December 2017, 06:44 PM   #14
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
^ Doesn't everyone, have you a solution?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 19th December 2017, 07:34 PM   #15
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
I found this:
A Loudness-Compensated Level Control Stage
Old 19th December 2017, 07:55 PM   #16
That's a very good article, now try and find a 10% tapped pot
Old 19th December 2017, 08:05 PM   #17
ALPS 100KAX2 100K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
Old 19th December 2017, 08:20 PM   #18
Have a look at fig 5, that is a special pot with an extra connection 10% of the way along the track in addition to the usual 3.
Old 19th December 2017, 08:44 PM   #19
^ It has a tap but I don't know the percentage.
Hard to find it seems.
Old 19th December 2017, 08:47 PM   #20
Yes, it says 10% in the text. I've not seen that before. There are some centre tapped pots available usually sliders they used to be used quite extensively in graphic equalisers. And I've seen centre tapped pots used in variable loudness controls.
Help me design my home music system amplifier with loudness controls.Hide this!Advertise here!
Announce: SeeDeClip4 multiuser home music streaming system, free/paid upgrade. Globulator Vendor's Bazaar 0 25th May 2017 08:26 AM
Humming sound coming out of home stereo system instead of music what is causing this Zips1954 Solid State 18 22nd February 2017 07:58 PM
Which approach for best results? Home theater and Music system? ORNJ Multi-Way 3 5th September 2013 03:00 PM
DIY Amps for New Home System - Music & Movies chuckd Solid State 0 18th February 2013 07:38 PM
Loudness controls M Gregg Tubes / Valves 8 5th July 2012 07:44 AM
