Old 4th April 2004, 04:42 PM   #1
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Default strange opa541 problem
hey guys,
when listening to an opa541 based chipamp we encountered a strange problem. It seems as though in the mid-high frequencies (guitar, loud voices) the chip is distorting the signal waaaayyy too much. You can hear a sort of "crackle" in the guitars & stuff.
we've tried gains of ~22 and ~15.
supply voltage = +/- 21VDC
nu current limiting used (the opa doesn't have an active current limiting system, you have to include a resistor to do this).
offset is pretty low, ~2 / ~4 mv.
we've checked all wiring and it seems to be OK.
any ideas?
Si fractum non sit, noli id reficere!
Old 4th April 2004, 07:36 PM   #2
matjans's Avatar
as per the datasheet i included a 0.1 ohm 5w resistor for current limiting. didn't help.
nasty!
Old 4th April 2004, 07:47 PM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Can you measure the distortion with a scope? Sine wave, square wave?
Is the distortion volume dependent? Or load dependent perhaps?
Old 4th April 2004, 08:13 PM   #4
matjans's Avatar
i can't measure it (no scope at hand) but i used trueRTA to feed it a single frequency and (strangely enough) i couldn't hear any distortion... tried everything from 200hz up to about 18khz. pink noise doesn't give me any audible distortion either.
distortion is neither volume nor load dependent. tried 4ohm and 6ohm speakers at different volumes. Distortion is still there.
i tried the cd player with some other amps but it's fine.
Old 4th April 2004, 08:26 PM   #5
Netlist's Avatar
I don't know trueRTA but I see they have a built-in scope.
In your case I would only trust a good scope picture.
Did you play with different supply voltages. Isn't +/-21V a bit low?
Old 5th April 2004, 02:16 AM   #6
matjans's Avatar
o well, leave it. the guy ripped out the 541's and built one with 549's. works like a charm
strange hum problem zeus_threat Solid State 8 18th December 2007 02:55 PM
strange amp problem!!! moonchild Solid State 23 14th January 2006 12:05 PM
Strange problem with amp lumanauw Solid State 10 12th March 2004 12:59 PM
Strange little problem (or maybe not so) elizard Chip Amps 8 4th January 2004 06:25 AM
Page generated in 0.08615 seconds (65.99% PHP - 34.01% MySQL) with 10 queries
