Chip amp decoupling/snubberizing caps
Old 7th December 2017, 08:24 PM   #11
DF96 is offline DF96  England
If you omit the 0.1uF bypass caps in the PSU then you might not need the PSU snubber. The electrolytic ESR will dampen any resonance created by the local chip decouplers. As others have said, any film cap will do.
Old 7th December 2017, 09:30 PM   #12
00940 is offline 00940  Belgium
00940's Avatar
Make Cs 4.7uF/100V X7R. Such caps were not easily available when the datasheet was written but since they are now we might as well use them.
Cz can be mkt without any worries. Don't waste money on a mkp there.
Btw, your schematic is incomplete. You are missing the network in // with the feedback resistor (Cf-Rf2 in the datasheet) and one cap in between the + and - inputs (Cc). The single supply schematic is strangely more complete than the dual supply one in the datasheet.
You might also want to add an input cap (safer if you don't have an offset protection) and increase the feedback capacitor to 100uF.
All that is excessive is insignificant. Talleyrand
Old 7th December 2017, 10:58 PM   #13
ggidzinski is offline ggidzinski  United States
Originally Posted by Mark Whitney View Post
I think this is the one used by chipamp.
BFC241641004 Vishay / BC Components | Mouser Europe
Thanks. That's the closest offering from BC to the original blue box caps but they changed the width.
George
Old 8th December 2017, 09:03 AM   #14
R.I.P.
The 1r0 snubbers are in the wrong place on the output of the PSU.
They should be across the transformer secondaries.
DF said
remove the 0.1uF, it can only increase the risk of ringing.
DC block on the input missing. (22k suits either 4u7F BiPolar, or two 10uF back to back)
RF attenuation on the input missing. (1k0 suits 330pF to 1nF across the 22k)
DC block on the NFB lower leg far too small. (680r suits 220uF, or 330uF)
00940 said
read the datasheets again and ask if you don't understand.
regards Andrew T.
Old 8th December 2017, 09:04 AM   #15
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Snubbers are placed across switching elements, often across rectifiers, I presume they were adopted by the gainclone community due to the minimal smoothing used in the design and their small size?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 8th December 2017, 09:22 AM   #16
R.I.P.
Yes, across the ~~ terminals since this is effectively across the secondary.
because he did not know what the effect of adding the low esr cap to the inductance in the nearby circuit when a step change in current was imposed.
regards Andrew T.
Old 8th December 2017, 10:23 AM   #17
There is a certain school of 'design' which always adds a 'bypass' across every big cap, and scatters 'snubbers' liberally around (yet sometimes avoiding the places where a snubber might do some good). In some cases, the otherwise unnecessary snubbers deal with the harm created by the unnecessary bypasses.
Old 8th December 2017, 04:46 PM   #18
I may need to rethink my approach. I chose the Chip Amp.com boards as my starting/learning point for my first gain clone build. The schematics I provided are those boards and BOM. After reAding these comments it appeRs that this design is not held in high regard, although I am learning a lot. I have a few other boards, maybe I'll post the schematics and see if any of those get better reviews.
George
Old 8th December 2017, 05:13 PM   #19
R.I.P.
it is often possible to add components or change components to a pre-made PCB.
Have a good look at your PCB and see what mods/additions are feasible. This is a really good learning experience in becoming familiar with the PCB, it's layout, what each component does and what is possible to change in someone else's design.
Only where all your desired and some of the NEEDED mods are impractical do you throw the PCB away.
regards Andrew T.
Chip amp decoupling/snubberizing capsHide this!Advertise here!
Tda1541 decoupling caps Green77 Digital Line Level 13 13th March 2015 06:03 PM
UCD snubberizing, already done? Bgt Class D 72 6th October 2005 03:17 PM
Decoupling caps(again) argonrepublic Parts 2 10th May 2005 10:32 PM
decoupling caps argonrepublic Parts 4 8th May 2005 10:20 PM
decoupling caps question audiokid25 Parts 6 28th October 2004 09:56 PM
