CRFX said:Hey guys, been lurking on the board for a while diggin up ideas for my 12 channel GC.
Got the amp pretty much planed out, just looking for small transformers, 1 for each channel. Around 500ma or less is all i need. Don't really wana spend $20 per channel just for power.
are you making a 10 watt per channel, 12 channel gainclone?
what are the transformers for?? lol
Re: Re: small transformers?
actually... make that 5 watts per channel..
Decoupling bridges from a transformer
Hi Woody,
Could you please explain the need to decouple the bridges from the transformer and how the value of the resistor is determined.
I was considering powering two bridges off the same secondary to get +/- rails.
Hi Woody,
So why not use 1 large transformer to feed your 12 bridges each bridge being decoupled from the transformer by a pair of 1 ohm resistors ?
actualy, yes.
10W per driver is more than enogh for me, and thats blasting to me. I barly use 10W for all 12 for normal listening. Also I'm using an active Xover so that 30W for my 2 3 way speakers and 20W for the 3 2 ways.
Power is a non issue for me, i just want it to sound its best.
actualy, yes.
Re: Decoupling bridges from a transformer
I second that. I really like to know why the decoupling resistor is needed.
cheers
Ric
ped said:Hi Woody,
cheers
Ric
Math time...
500mA * 16 ohm speakers (worst worst case) = 8Volts peak or 16Vp-p that you'd have to drive. So that pretty much tells you waht you're looking for. 16 / 1.414 = 11.31V. So. you need at minimum a 12VCT 1A transformer (for a little headroom) per channel. The only problem is that a LM3875 needs minimum 20V rails. So now what you need is 20 / 1.414 = 14.14V. So you'll need something like a 14VCT 1A transformer.
All electronics has an 18VCT 1A transformer for $4. That might be a good candidate for your project.
But now you know what you're looking for.
All Electronics Transfomers
Danny
thanks so much, thats just what i'm looking for.
btw im using lm1875s, so 12V works fine for them. I have 6 drivers on 1 12V 3A transformer with no probs. 1A each will be more than enogh.
1 more question, how well would a 1875 work instead of the 3875 in BrianGT's gainclone.
CRFX said:1 more question, how well would a 1875 work instead of the 3875 in BrianGT's gainclone.
OK, it's not the first time I hear people comparing 1875 with 3875. I really don't know what is going on. 1875 is still so far away from hi-end, no matter how hard I've tried (and I used tantalum resistors). I felt so stupid using expensive stuffs for that "cheap" IC
Don't spend $80 dolloars for the LM3875, spent $35 and get the basic kit from Brian here:
http://www.briangt.com/order/
Troy
Troy
- Chip Amps
- small transformers?
