Main power fuse in Technics SU-300 blowing
I'm currently trying to reapair a Technics SU-300 Amp. The Main Fuse F1 (at the primary side of the transformer) blows when the main power button is switched. I already found at that the transformer is ok by disconnecting the transformer from the pcb with the rectifier diodes (D601 to 604) (--> fuse didn't blow). I also measured the resistence of the diodes in both directions while they were still soldered in but surprisingly all of them showed a resistance of several kOhm in both directions. Any advice on this? Should I dissolder them and try again?
I also measured the resistance of the capacitors C130 and C131. It was in the MOhm range, so I guess these should be okay.
Here you can find the schematic (German / EG-Version:
http://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Technics-SU-300-Service-Manual.pdf
Thank you!
Administrator
Joined 2007
Use a bulb tester. This will save damage and fuse blowing.
Large diodes usually fail short circuit and so at this stage I would accept that they are probably OK. Any slight residual voltage (charge on caps) will totally confuse most DVM's when checking resistance, that said a short will always show.
Most likely failure is the power output chip. This is easily proved by unsoldering the supplies to it and then seeing if the amp powers up.
