| Chip Amps Amplifiers based on integrated circuits |
Hi everybody,
I thought that I would share with you my second GC attempt. I think it looks nicer and IT WORKS I would appreciate your comments. Here are the pictures: |
#2 |
Here is a picture of the closed case...
This is based on the Peter Daniels' design with Brian's boards. I have one problem though. I keep blowing fuses (between line and the primaries of the transformer). I have used 250V 4A and no luck. Any suggestions...? |
#3 |
COOL!
It seems that the TRUNK Router inside the network.very ahead fashion. |
#4 |
Thanks for your comment. I really appreciate it.
What do you mean by Trunk Router? ![]() Cheers, Rafal |
#5 |
diyAudio Moderator Emeritus
Rafal,
Looks good! What are you going to do with the second set of pcbs that I sent you? As for the fuses, are you using slow-blo fuses? I am using a 3A slowblo for mine, and have never blown it. Others have said that a 2A slowblo also works fine. Are you blowing fuses at turn-on? I added your pictures to my new gallery of finished amps with my boards: http://brian.darg.net/gallery/nigc -- Brian |
#6 |
The big red caps, are they on the inputs?
Love the dimond plate. |
#7 | |
http://www.briangt.com/gallery/nigc To others with finished project using my kits and pcbs, feel free to e-mail me pictures, or post them in a thread, and I will add them to my gallery. -- Brian |
#8 | |
cheers! |
#9 | ||
I was toying with the idea of buildiing a second amp fo an active amplification of jordan 2-way, but for now, I will build a set of horns instead. The boards will have to wait a little longer. Maybe I will make an amp for a buddy. Quote:
The big red caps are for ensuring low dc offset. they are placed between Reiken 680 ohm and signal ground Thank you all for your comments Cheers,
| First attempt at quasi fiberglass sub, almost finished (pics) | eRiCdWoNg | Subwoofers | 5 | 23rd April 2004 06:00 AM |
| Page generated in 0.11007 seconds (68.06% PHP - 31.94% MySQL) with 11 queries |
