Speaker vibrate no signal
Old 5th November 2017, 08:33 AM   #1
rahulrahullll is offline rahulrahullll
Arrow Speaker vibrate no signal
tda 2050 working sound ok
components tightly soldered--dual rail--16.5-0-16.5 v transformer--2200 uf/50 v 2 caps
--but----
signal cable not connected------speaker vibrating little bit
signal cable connected--------speaker vibrating little bit----but when signal cable is adjusted pushing a little bit inside in pc sound out jack---no speaker vibration
---------IS THIS NORMAL THING OR ANY PROBLEM ? ---------
Old 5th November 2017, 08:40 AM   #2
Mooly's Avatar
Do you mean hum ?
Yes, it can be normal for an unterminated input to pick up noise. If you short the input to ground (shorting plugs) then the amp should be silent.
Old 5th November 2017, 09:37 AM   #3
am i able to explain now clearly
signal cable not connected, when i touch the speaker it is vibrating little bit
signal cable connected, when i touch the speaker vibrating little bit, but when signal cable is adjusted pushing a little bit inside in pc sound out jack, no speaker vibration
Is this normal or any problem?
Speaker vibrate no signalHide this!Advertise here!
LED from speaker signal Llama16 Full Range 5 17th December 2011 04:53 PM
Subwoofer design to vibrate water in a pool? pikipupiba Subwoofers 39 11th June 2011 08:16 PM
projection screen will vibrate? JinMTVT Multi-Way 10 5th January 2008 07:14 PM
Speaker's Fr variation with signal level gpapag Full Range 32 5th August 2005 08:43 PM
Controlling speaker signal with diode? DJFUTILE Multi-Way 3 19th June 2005 07:10 AM
