LM3886 gainclone DC servo
Old 6th November 2017, 01:42 PM   #21
Mooly's Avatar
The LF411A is the one with a typical 0.3mv offset voltage, the standard version is around 0.8mv still below the TL071 though but how much DC precision do you need for a servo ?
I just measured the offset on my amp which uses TL071's and the figures were 2.6mv on one channel and 0.9mv on the other... although as you may recall my amp actually derives its bias voltage from the servo output. In other words it is not simply a correction voltage but it biases the whole amp to the correct operating point.
Old 7th November 2017, 09:51 PM   #22
ICG is offline ICG  Germany
ICG's Avatar
I just want to remind that the DC offset is also dependent on the surrounding circuit, feedback and especally tolerances. That means, the offset can be compensated by the circuit/feedback or become worse by tolerances of the OPs and the resistors. That means, the 'off' isn't always the falut of the OP and before you claim OP xy isn't suitable/bad for the DC servo, you should probably check if something else is 'off'.
There are also schematics which correct the offset by using the 2nd OP (with assumed almost identical behaviour) by compensation by the 2nd OP of the same IC. If there's a remaining DC offset it might also be because of the following amplifier stage or amplifier chip. The final DC offset can be ignored in many cases but with PBTL or even multi-PBTL use the tolerances have to be much stricter to avoid power lossed due to the ICs compensating each other and much power potential is wasted by that, resulting in a much lower output and a lot higher heat dissipation or even burnt up components.
Is that a 6x LM3886 PBTL or 3x3886 PBTL amp board? Or 'just' a 6ch amp? If it is the former, that would mean, if you want to know if it works as intended, you have to measure each IC DC offset separately for each IC and if it's too far off, the DC servo of the particular amplifier IC might have to be modified or parts have to be switched. Just solder the parts in and/or substitute a few parts in such a DIY kit will probably not work up to the max specs if you leave out that part of testing, the more ICs are used parallel, the worse it gets.
I had a Déjà Moo - I've seen that BS before!
Old 16th December 2017, 05:58 PM   #23
asuslover is offline asuslover  Romania
Maybe a stupid question, I have to ask: if I parallel 2 of lm3886 chips then each of them must have their own servo?
I have finished lm4780 parallel with servo and the paralleled halves of the chips were sharing the same servo circuit.
Old 16th December 2017, 07:25 PM   #24
Mooly's Avatar
Not necessarily although it would require some thought in the design.
Paralleling chips usually involves a low value series resistor on the output of each before summing to a single output. That prevents small differences in voltage from generating massive currents as the chips 'fight' each other trying to source and/or sink current between themselves.
If both amps to be paralled are designed correctly then I would say the offsets should be very similar and lend themselves to a single servo. A dual servo would also tend to cause massive currents to flow, particularly at power on due to slightly different time constants and so on.
Tom Christian is the one to ask on this as he has done more with the LM3886 than most.
Old 16th December 2017, 09:16 PM   #25
Thanks, I actually finished his parallel86 amp, works great, but now I am thinking playing with DIPTrace and trying my own design .
LM3886 gainclone DC servoHide this!Advertise here!
LM3886 Servo Design Redshift187 Chip Amps 67 3rd September 2017 11:13 AM
LM3886, XO, Buffer and Servo jackinnj Chip Amps 3 30th October 2008 12:14 AM
Gainclone LM3886 DC servo peranders Chip Amps 10 24th March 2004 04:59 PM
