Hi, I have a some LM4881 chips and have built a headphone amplifier for my portable CD player. The sound is excellent, so I would like to bridge them. The problem, though, is that they only have one input. Is there any way to bridge them short of using something like a DRV134 to invert one amp's input?
thanks!
mike
thanks!
mike
like the DRV134 right? that takes one signal, invertes it, balences the inverted and non-inverted inputs then has two outputs of the same signal, inverted and non-inverted.
The only problem with that is I only have one and would need two for stereo. I don't think with headphones you would notice the difference when one amp is inverted and not the other, so I could just stick an inverting opamp before the input of one of the amps, right?
- Chip Amps
- bridging an LM4881 headphohne amplifier? Can it be done?
