| Chip Amps Amplifiers based on integrated circuits |
its a 20w amp based on a ic, lm1876.
im not sure its properly baised, plz check me. thx 2 all that reply. [IMG]C:\Documents and Settings\roey prat\My Documents\electric data\complete 20w amp.bmp[/IMG] |
#2 |
i hope u can c it this time...
#3 |
Aaahh, don't quite know where to start.
Doing a quick calculation on the voltage divider you use to get ground from single power supply: 40Vac * 1,4 = 56Vdc = 28V / resistor Ir = 28/2.5 = 11.2A Pr = 28 * 11.2 = 313.6W / resistor So, you're looking at burning 627W just to get 20W output power. I suggest that you either replace the resistors with something like 100 ohms parallell with 2200uF, or place a 4700uF cap on the output. Or better, get a centre tapped transformer. Rune
Do wizards use spell checkers? |
#4 | |
Otherwise you might as well connect the IC as a single supply configuration with an output cap. /Greg |
| PCB Check | Khron | Chip Amps | 48 | 28th May 2006 09:55 PM |
| PSU check | ifrythings | Power Supplies | 7 | 21st April 2006 04:56 AM |
| my first amp, please could someone check it??? | Si992 | Solid State | 17 | 15th March 2005 09:05 PM |
| Page generated in 0.07738 seconds (77.70% PHP - 22.30% MySQL) with 11 queries |
