Old 30th March 2004, 01:35 AM   #1
Default probably a stupid questions about opamps
can an opamp be used as a voltage amp? I want to boost 12V to about 40V.
Basically, a car amp power supply.
thx,
mike
Old 30th March 2004, 01:40 AM   #2
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
You may need DC-DC chip of solid state.
Old 30th March 2004, 01:59 AM   #3
An opamp is designed to output voltages within it's supply limits. Unless you used a transformer to step that voltage up, you won't get any higher voltages out of the amp.
As digi01 has stated, you may want to look into a DC-DC converter.
-Dan
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers".
A stupid questions about fuse, please help goldkenn Class D 8 30th September 2008 09:23 AM
Stupid Class D Questions Mat_89 Class D 1 19th February 2008 03:39 PM
Stupid PAS-2 Pot Questions neddyboy Tubes / Valves 5 7th June 2007 12:26 AM
Some simple/stupid audio questions Eric_B_C Everything Else 8 2nd January 2007 11:39 PM
Page generated in 0.06299 seconds (67.41% PHP - 32.59% MySQL) with 10 queries
