Old 30th March 2004, 01:22 AM   #1
ekd is offline ekd  United States
ekd's Avatar
Default Check my chip mods?
Is there any sonic penalty to using ribbon this way?
E
Old 30th March 2004, 01:29 AM   #2
yup, oscillation, i tried this with the lm1875 and the chips oscillated badly
Old 30th March 2004, 02:36 AM   #3
ekd's Avatar
Default Fix?
What did you do about it?
E
Old 30th March 2004, 04:50 AM   #4
ir is offline ir  New Zealand
Send a message via ICQ to ir
it'll work on the condition your ribbon cable is no longer then 1 - 2 inches AND you will NEED to solder the 0.1uF bypassing caps directly to the chip just like the feedback resistor
then it should be alright. on th eamps i've built on perfboard i've had to shift the even numbered pins out to the side so they're ona seperat track, the wires for this are only an inch tho and i've never had any problems
Old 30th March 2004, 11:51 AM   #5
Default Re: Fix?
E
I made a pcb for it.
Please check this out Vaughan Subwoofers 15 29th January 2009 04:03 PM
PCB Check Khron Chip Amps 48 28th May 2006 09:55 PM
PSU check ifrythings Power Supplies 7 21st April 2006 04:56 AM
Please check this xo for me kifeinthesink Multi-Way 1 3rd January 2006 08:14 PM
Check this SOZ out! PedroPO Pass Labs 5 8th July 2002 11:52 AM
Page generated in 0.06574 seconds (76.51% PHP - 23.49% MySQL) with 11 queries
