Old 28th March 2004, 06:49 PM   #1
xplod1236's Avatar
Send a message via AIM to xplod1236
Angry single supply for lm3886
Can someone explain how a single supply works?
I want to build an amp using lm3886s, but my ps is +/- 50v. I want to use +50v and 0v to power the amp. I've looked at the schematic, but I still don't get how it works. One side of the speaker coil is connected to gnd, but what goes into the other side of the coil? +50v from the amp? That will only move the speaker one way.
Will a single supply move the speaker both ways?
Old 28th March 2004, 09:32 PM   #2
runebivrin's Avatar
Send a message via MSN to runebivrin
As with most single voltage amplifiers, there's a cap between the output and loudpeaker that "eats" the offset voltage.
Rune
Do wizards use spell checkers?
Old 28th March 2004, 09:46 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
First check the datasheet of the LM3886 carefully.
How it works?
The input signal is lifted up to (in your case) 25 volts. This means you will get 25 V out when you have no signal. When you apply signal the out will swing around 25 volts. This 25 V DC is filter out by a large electrolytic cap, 4700-10000 uF. Your speaker is connected with this huge capacitor is series and then connected down to ground.
Just check page 6 in the datasheet.
/Per-Anders (my first name) or P-A as my friends call me
Old 28th March 2004, 09:53 PM   #4
xplod1236's Avatar
Would bridging 2 lm3886s both running off a single supply work the same way as if they were running off a +/- supply?
Old 4th April 2004, 11:18 PM   #5
xplod1236's Avatar
anyone?
Old 5th April 2004, 02:03 AM   #6
leadbelly's Avatar
If you bridge 2 LM3886's built single-supply per the datasheet schematic, you need a phase splitter in front of them since both chips will be non-inverting. Something like a DRV134 will do the job of buffering and phase splitting before the LM3886 stage.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Using a 50v single supply (and trying to split it) with LM3886 mudihan Chip Amps 47 9th March 2009 08:12 AM
Single Supply Amp help - LM3886? GePeW Chip Amps 104 22nd November 2007 11:38 PM
Using single CT supply with LM3886 TDWesty Power Supplies 0 15th March 2007 05:37 AM
LM3886 single supply. unitgain Chip Amps 2 24th March 2004 01:10 PM
Page generated in 0.07825 seconds (73.53% PHP - 26.47% MySQL) with 10 queries
