GC Power Supply Trouble
Old 18th May 2004, 01:05 PM   #51
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Is it soft 50 Hz hum or hard 100 Hz with harmonics?
100 Hz, which I'll guess you have => how have you connected the center tap, smoothing caps, speaker ground, signal ground?
Think like this:
signal ground
speaker ground
caps ground
transformer ground (center tap)
This is the order you must connect the ground in.
The thing which causes the hum is charging currents in the smoothing caps. A couple of milliohms and 1 A in the charging peaks (just an example) => millivolts in hum!
Can you take a photo or do a simple sketch?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 16 pcb's in interest.
Old 18th May 2004, 01:16 PM   #52
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Actually my torroid is 500VA, 2X 25V, 220V Nuvotem Talema one. The circuit was for Peter Danial's circuit, the rectifier bridge used MUR860. Did checked the circuit a few times and seemed to be dandy, plugged into the powerline and the smoothing caps (polarised BG 4.7uF) fried. Is my VA rating way too high? I am really lost friend. Please help....
Tops, you seem to be confused if you are using 4.7's for smoothing caps!
Please post your complete circuit (including PSU) for us to have a look at and see if we can help you!.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 18th May 2004, 01:28 PM   #53
peranders's Avatar
tops, if 4.7 uF is the only capacitance, you have a small problem! 1000 uF at least!
tops, your sig "Less is more", but sometimes more is more.....
Old 18th May 2004, 04:06 PM   #54
Herman is offline Herman  Germany
Default GC Pwr supply
Hello P-A,
thanks for the quick response.
I attach a picture of the (2 channel) setup. I use a star ground. The big filter caps are removed at the moment and therefore not in the picture.
Herman
Old 18th May 2004, 04:07 PM   #55
Default Picture
Sorry, forgot to attach the picture...
GC Power Supply TroubleHide this!Advertise here!
Trouble choke loading tube in regulated supply phrarod Tubes / Valves 19 14th June 2009 07:13 PM
TubelabSE power supply trouble wicked1 Tubelab 26 14th December 2008 08:59 PM
More GC Power Trouble rampage101 Chip Amps 1 8th April 2004 02:58 AM
Having trouble building a power supply for a phono preamp SideA Solid State 1 4th April 2003 07:34 AM
