diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Linkwitz Transform? (http://www.diyaudio.com/forums/chip-amps/31089-linkwitz-transform.html)
Aunkst 28th March 2004 12:01 AM
Linkwitz Transform?
Has anyone had any success with a Linkwitz Transform? What set up are you running with? Any schematics?
I spent this afternoon playing with a rudimentary LT, and I found that it sends my amp into protection mode pretty quick also I got some ocillation. except for that I think the concept is good. I just need to tweak it .
Nuuk 28th March 2004 08:31 AM
What amp are you using it with?
Aunkst 28th March 2004 11:57 AM
nothing special. Just a 200 watt cheapie that I won't be disapointed if I burn it up.
It is an Audiosource Amp 1 from the Ebay.
I now that it is not the best sub amp
soundNERD 28th March 2004 01:19 PM
to make it a better sub amp i remember seeing a circuit to do this by bridging the amp. i think it was at www.sound.westcoast.com or something like that.
dex-rex 28th March 2004 03:28 PM
You probably checked this, but just in case http://sound.westhost.com/linkwitz-t...rm.htm#example
I`m using input mixer/summer shown at the 1st schematic and fig.2 LT at http://sound.westhost.com/project71.htm with no issues whatsoever. As to your problems, you could change the high pass filter from 7 Hz showed in original circuit to somewhat higher or to change the slope to 12 db/oct. Not confident about HF oscilattion origin though. My setup is TDA 7293 amp, 80W or so, 10` "can`t remember" driver in 25 L, worked superb from the first try. Be sure to use capable drivers (high power/long stroke/large diameter/stiff cone) measure Qts if possible and take advantage of equalisation freedom- set it to Q 0,5. Best bass out of box IMO.
moving_electron 28th March 2004 06:33 PM
At the risk of posting twice (I think there is a thread in Chip aps and solid state?)
Might be worth buying the circuit board, as the circuit will be more fully developed and debugged. The results will be more deterministic. I have not seen anyone mention oscillation concerns with the PC board implementations.
If you buy via credit card and let the card do the conversion the price will likely be better than the PayPal price.
____________________________
"Better living through controlled electron movement"
dex-rex 29th March 2004 12:59 AM
Just forgot to say of good practice to solder 100R on each OP`s out pin, or as close as possible. This should prevent some oscillation...and yes, PC board is probably the safest way to go if you`re not about to experiment.
Good luck on your LT project,
Copyright 1999-2017 diyAudio
