Is this a good LM3886 Kit?
Old 5th November 2017, 10:21 AM   #131
Mayday is offline Mayday  Sweden
Project Horder & Blogger
Mayday's Avatar
A 0-24Vac + 0-24Vac 500VA from toroidy and a total of 6 10000uF capacitors, of those 4 are on a board with rectifier diodes. Don't recall the model, they are TO-220 type diodes.
The more you learn, the more you realize how little you know...
My blog, go have a look
Old 5th November 2017, 01:54 PM   #132
dotneck335 is offline dotneck335  United States
That's a LOT of capacitance! I like it!! I used two of these instead:
380LX333M050A082 Cornell Dubilier - CDE | Mouser
as it was a little bit less $$ and smaller than 3 x 10,000uF. Have you considered a regulated supply like this?:
High current dual rail regulator kit for power amplifier or bench power supply ! | eBay
Old 5th November 2017, 02:27 PM   #133
Mayday's Avatar
No, I have the other stuff mentioned.
I've not considered getting a different supply for this amp.
Old 6th November 2017, 12:06 PM   #134
Mayday's Avatar
The heatsink arrived today.
Some pics attached The 3mm thick alu-sheet looks very big lol
Old 12th November 2017, 05:30 PM   #135
SpirosD is offline SpirosD
I`m watching how it goes. Well done ! I`m interested in as I have one kit on order.
I have an older LM3886 dc servo implementation which also has NE5534 as an input buffer or gain or something (I don`t know).
I have listened to this older one and I was very pleased. But I will do the new one too.
My questions:
As NE5534 is not unity gain stable and needs at least 3x gain then is this kit implementing such a gain? Maybe if I calculate well it is on 5x ?
Is the 523 Ohm an input NE5534 resistor and if so should be matching the value of the gain setting resistors? I mean in the older one there are three resistors, RR1A, RR3A and RR4A where RR1A should be 1K based on the values of the other two, you can see the attached schematic of the old one. I don`t recall where I had read about it neither the calculation formula but back then I was looking at it I was convinced it must be 1K or there will be a DC offset. Am I right on this? Am I missing something?
Is the supplied regulator for the uPC1237 a 7824 and not a 7812 one or the stuffing drawing is false?
What is the lead spacing required for the 4.7uF input capacitors? Can you measure?
Is the 10R supposed to be 10R or 10K? (as there is no schematic)
Old 5th December 2017, 05:56 PM   #136
Is there any progress on the build?
My kit arrived today, have not looked at it though. I`m a slow builder, the previous one is not finished yet...
But I would like to hear how it goes.
Old 2nd January 2018, 09:49 PM   #137
r_kalar_2 is offline r_kalar_2  Bangladesh
Any update? I am thinking to get this kit. Please share your experience.
Old 4th January 2018, 07:18 AM   #138
Mayday's Avatar
No,
Everything is ready to be mounted in a case, but I have not gotten around to it.
Old 4th January 2018, 11:50 AM   #139
I will eagerly wait for your update. On the surface, the kit looks very nice. If it's as good sounding as it looks, it's worth the money I think.
Old 4th January 2018, 12:26 PM   #140
NE5534 datasheet says:
"The op amps are internally compensated for gain equal to, or higher than, three. The frequency response can be optimized with an external compensation
capacitor for various applications (unity gain amplifier, capacitive load, slew rate, low overshoot, etc.)."
It says that they are internally compensated for gains > 3; so use of an external capacitor in the compensation circuit is required for unity gain operation. NOT that they are unstable at unity gain.
Is this a good LM3886 Kit?Hide this!Advertise here!
WTB:good money paid for good phono stage Thomas Giz Swap Meet 5 13th October 2014 05:51 PM
Lookin for a good amp for my PA???? What's a good reliable brand and model?? Juggernaut450 PA Systems 4 20th May 2013 12:17 PM
Good general purpose opamp with good DC specs? speakerguy79 Parts 1 17th November 2006 04:10 AM
Good switch for Stepped attentuater, Good cheap RCA jacks pjpoes Parts 20 10th March 2005 08:47 PM
