Mod-286 build thread
Old 10th August 2018, 09:20 AM   #171
ukhopeful is offline ukhopeful  United Kingdom
Default Now with added Guardian-86 goodness
Old 10th August 2018, 12:05 PM   #172
Default Trigger and remote control
No nasty pops on power on and off now Guardian-86 has been included
YouTube
Old 10th August 2018, 04:34 PM   #173
HarmonicTHD is offline HarmonicTHD  Switzerland
YouTube
Nice.
Although I never had any pops during power on / off. At least not if I switch on the source first and even then itís barely audible.
Old 10th August 2018, 07:25 PM   #174
tomchr is offline tomchr  Canada
tomchr's Avatar
I always power up from the source to the speaker and power down from the speaker to the source. No pops here.
If you leave the power amp on and turn on the source, you'll likely get a pop as the source's output comes up. There's really no way around that. After all, a pop caused by the source powering up is indistinguishable from any other signal from the power amp's point of view. The amplifier will do its job and amplify the input signal - even if the input is a pop from a source powering up.
If I was to design a system from end-to-end, I'd either control the power-up sequence of the various pieces of equipment or have each output feature a mute switch. There are advantages and drawbacks of both of these approaches.
It's good to see the Guardian-86es being put to good use, though. Thanks for sharing your build pictures.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 10th August 2018, 08:18 PM   #175
The problem I had was at power off. When the preamp triggered the power amp, the power amp powered down more slowly that the preamp. One solution would be to delay the preamp power down which would require a firmware change to the control board I am using. Since that is not possible yet, the Guardian-86 fixes it by muting the speakers quickly enough.
Old 10th August 2018, 09:04 PM   #176
tomchr's Avatar
Yeah. It does take a bit for the supply caps to discharge. Thanks for clarifying.
I'm glad the Guardian-86 worked out well for you.
Tom
Mod-286 build threadHide this!Advertise here!
Cheap (<100Ä) Digital Tube Tester from ebay; experience/build/mod thread pauldune Equipment & Tools 21 17th April 2018 07:21 PM
Need help to build a system around Modulus-286 alexwey Chip Amps 11 26th May 2017 01:32 AM
rewiring a Sony PUA-286 tonearm eidling Analogue Source 1 8th October 2006 06:43 PM
