| Chip Amps Amplifiers based on integrated circuits |
I built a 3886 amp, and the heatsink gets slightly warm when there is no signal. not hot, not even warm, but warmer than when the amp was off. I understand the trafo getting warm, but why the amp? I have a 8ohm speaker connected to it, and a 500ohm resistor across the input wires. There is absolutely no sound in the speaker, not even the slightest hiss, but it still gets slightly warm.
My understanding was that this chip should stay as cold as when turned on with no signal. Am I wrong? thanks, mike |
#2 |
Electrons are yellow and more is better!
The idle current is around 50 mA so if you take that and the voltage across the IC you can calulate the power. = not cold without heatsink
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
OK, thanks!
| How do I turn an high current signal into a line level signal?? | sardonx | Tubes / Valves | 8 | 27th August 2005 11:16 AM |
| SI T-amp warm-up? | irss | Class D | 3 | 8th April 2005 11:40 PM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 06:51 AM |
| Creating a differential signal from a single-ended signal for bridged amps | Peter Daniel | Chip Amps | 45 | 8th November 2004 12:47 PM |
| My amp gets warm... | Jye | Multi-Way | 6 | 21st November 2003 11:53 PM |
| Page generated in 0.07879 seconds (74.68% PHP - 25.32% MySQL) with 10 queries |
