| Chip Amps Amplifiers based on integrated circuits |
how much power can the opa541 deliver? how about the other OPA chips?
I want to power an 8" 8ohm sub with it. the chip I would use is the plastic package. thanks! -Mike |
#2 |
My friend just tried the OPA541 because he thought the JFet input might be good. Using the same circuit as 3875 (25Vdc,22K/680 R) on 8Ohm speaker, the sound not much different as expected. Particularly compared the cost (US$16.xx for OPA541 compared US$4.xx for LM2875). Probably, it might be good for 4 Ohm speaker I guess.
#3 |
OPA541AP can deliever 5A continously and 10A peak.
[5A/(sqrt2)] * 8ohm = 100W RMS [5A/(sqrt2)] * 4ohm = 50W RMS This is just theoretically though. Max voltage for the AP version is +/-35V and it svings to approx. [rail - 4,5V]. The OPA549 can deliever 8A continously, but here the max voltage is lower (+/-30V). |
#4 |
Would have been fun though if the OPA512SM wasn't NRND. +/-50V and 15A peak
#5 |
If I were to use the 549 with an appropriate voltage, what kind of power levels can I expect?
#6 | |
and what does NRND mean anyway? |
#7 |
Not Recomended for New Designs.
That means that they have decided to stop producing them They don't deliever samples when a device is NRND
#8 | |
Banned
voltage should be somthing less +-(15V * 1,4) The amp: |
#9 |
Banned
The only expensive part on this amp was the transformer, 17,95€ Reichelt.
Connectors and Aluminium was from junk / University. Everything inside is point to point with 0,8 mm silver plated solid CU. Some steel between transformer and cicuit. Rectifier is made from some TO247 discrete diodes. Gain is 10, standart 1% metalfilm resitors used. |
#10 |
ok looks like im leaning toward the 541 for my sub amp?
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| Hypex UCD ST series vs. HG series | lotuss79 | Class D | 0 | 19th March 2009 02:46 PM |
| Yamaha CA-series / CT-series parts | DragonMaster | Parts | 9 | 19th January 2007 07:48 PM |
| Quality of Hammond 300 series power transformers compared to 200 series? | G | Tubes / Valves | 8 | 21st September 2003 02:27 PM |
| LM47XX series of chip amps | JoeBob | Chip Amps | 3 | 9th August 2003 06:46 PM |
| Page generated in 0.11997 seconds (68.13% PHP - 31.87% MySQL) with 11 queries |
