| Chip Amps Amplifiers based on integrated circuits |
whats the best value of components to use for a zobal on a 3886 amp? I have tried everything to get rid of the high frequency clipping bass notes cause, from adding more caps to the ps to changing gain of the amp. The distortion is still there. I am almost thinking it may have something to do with the zobal. Right now I have it connected like in the datasheet, 1k resistor on pin 3. but i used a 10uf electrolytic for the capacitor, not a 22uf non-polarized cap. Could this be the cause of the distortion?
Power is no problem, the trafo is from my old z680s so its capable of powering 500W of amps. It puts out dual 23VAC thanks, mike |
#2 |
I think you need to look at the data sheet again. The Zobel network is typically 2.7ohms in series with 0.1uF parallel with the speaker.
When you talk about 1kOhm and 22uF, I'm assuming you're actually refering to the feedback network. 10uF there will limit you bass response, as it puts the -3dB point at 15 Hz. Rune
Do wizards use spell checkers? |
#3 | |
#4 |
This discussion raises another (dumb?) question I've been pondering: Why do some schematics use an inductor and others a capacitor in the output filter? Are there any advantages of one over the other besides the fact that capacitors are easier to come by? Also, is there a source somewhere for calculating the cut-off of the combinations similar to that for a passive speaker x-over?
#5 | |
thats the thing, i have 8ohm 92db speakers, and they are not loud at all. I mean, yeah, they are loud, but no where near what about 50W should be able to do into 8ohm 92db. Will adding a zobal help anything? I will also change the 10uf to something else. Maybe 50uf to make sure i get as much bass as possible. |
#6 |
hello?
anybody? |
#7 |
It's hard to say whether a Zobel will help in your situation. Why don't you try it?
Does the chip get warm when it distorts? Rune
#8 | |
Electrons are yellow and more is better!
http://www.national.com/appinfo/audi...gn_Guide13.xls http://www.national.com/appinfo/audi...sign_Guide.pdf Good! http://www.national.com/an/AN/AN-1192.pdf http://www.national.com/pf/LM/LM3886.html Seriously, I think you ought to have 200 Watts or more. 50-70 Watts for your speaker will not make it to a party animal. 23 VAC is not max. You can have 28 VAC. This will maybe give you a couple of dB's more.
/Per-Anders (my first name) or P-A as my friends call me |
#9 | |
dave |
#10 | |
about the chip getting warm, yes it does. It gets warm like normal when the amp is running normally, but when it distorts it gets hot. |
| zobel question | sakis | Solid State | 11 | 26th September 2008 08:51 AM |
| zobel question? | fazman | Multi-Way | 2 | 18th December 2005 04:11 AM |
| Zobel Question | Soulwax | Multi-Way | 2 | 2nd May 2005 05:21 PM |
| Zobel Question | poeee | Chip Amps | 2 | 5th January 2005 05:29 PM |
| zobel question | soundNERD | Chip Amps | 17 | 10th November 2004 07:05 AM |
| Page generated in 0.19450 seconds (47.49% PHP - 52.51% MySQL) with 10 queries |
