| Chip Amps Amplifiers based on integrated circuits |
#501 |
diyAudio Moderator Emeritus
A 50W thermostatically-controlled iron will be far safer to PCBs than a 35W uncontrolled firestick.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#502 |
ok im an idiot. i wired the V+ and the pg+ backwards
but luckily i fixed it and it still works going to wire the pot as wildman noted right now. hope it works. i should get my dang camera by tuesday i hope. ebayer is lagging. but as soon as i do ill post picks. came out pretty decent i think. billet aluminum case with phenolic rear pannel with all the connectors int he rear and the noble pot in the front left. nice and small. hope there isnt issues with everything right next to each other.
#503 |
got it all wired up and its playing right now. sounds decent. any word on how long they take to break in?
#504 |
yes! I tested mine again, and nothing flied ! I'm really happy now
#505 | |
. Sure it'll do. I'm not sure about the temperature, I believe 350°C is OK, but then again I might be completely wrong and it should be 500°C. I'm sure someone here will tell you what a good temp is .
Website: http://members.lycos.nl/anthonyvh |
#506 | ||
What is a good temp to use for my Weller on PCBs? |
#507 |
Iron Temps Thread
Soldering temperatures (resistors, caps, transistors) Please comment more if you feel so compelled.
#508 |
Does any one know anything about this transformer? Will it work in a gainclone? How do I measure it (if I need to, that is)? It is out of a subwoofer amp (first picture; there's no picture of amp. I don't know how to attach more than one picture).
Black wire is V+ and red is V- and purple and green (or maybe just green?) are for each of the channels. These are just my guesses, does any one know the correct wiring? |
#509 | |
Measure for continuity between them. The black ones maybe a shield. With a DMM set for resistance you should be able to get them identified. Carlos |
#510 |
red-yellow-red have continuity between all three and all the pairs have continuity between each pair. On the sub amp PCB the black wires are labeled as "primary1" and "primary2." The black wires go to the plug in the sub amp. I don't have a DMM (just analog multimeter; measures only Kohm), can it be determined without one?
