Gainclone building thread based on BrianGT's boards - Page 2 - diyAudio
Old 24th March 2004, 04:40 PM   #11
speaker is offline speaker  United States
speaker's Avatar
Originally posted by BrianGT
The resistor is the negative feedback resistor. In order to obtain the best performance from the LM3875, the feedback look must be as short as possible. This component has the most effect on the amplifier's performance.
This resistor can be soldered right in front of the lm3875, or on the bottom side of the pcb.
Brian
Ah, that makes complete sense now and is an elegant solution. It appeared that you wanted it to track thermally with the output device and I could not figure why.
speaker
Old 24th March 2004, 05:40 PM   #12
speaker's Avatar
Originally posted by meat
There is more information on the top of this thread
Group order of non-inverted LM3875 pc boards? Anyone interested?
Thank you!
speaker
Old 24th March 2004, 05:43 PM   #13
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
speaker
I like the appearance with the resistor in the front the best.
Another option, if you are using the T package along with the thick thermal insulator, would be to place the resistor on the back side of the LM3875T, and you can probably even get it a bit closer to the actual leads. This is what I did on my prototype.
I do still like it best as pictured below.
Brian
Old 24th March 2004, 05:43 PM   #14
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Default Re: Fuse
Originally posted by vsr123
I think a 1.5A to 2A fuse should be enough. Not sure if you need a slow blow type though since the inrush current should be small. If you read other threads the general comment is to keep trying different fuses until they stop blowing! :-)
cheers
vsr
that's just what i did and i settled with an 1.5 amp sloblo fuse for use with a 225 VA toroid
Old 24th March 2004, 05:46 PM   #15
BrianGT's Avatar
Default Re: Re: Fuse
I am currently using a 2A fuse in mine. I had a 3A fuse in my previous unit. Neither of them has ever blown (both slowblo), so 2A should be fine. I haven't tried lower than 2A.
I am curious to see what the 2 channel Bridgeclone that I am looking at building will require (12 boards total on a 1kVA transformer)..... I am hoping that the 1kVA is enough for both channels, as I am not buying another transformer.
Brian
Old 24th March 2004, 05:58 PM   #16
Coulomb is offline Coulomb  England
Coulomb's Avatar
What's the secondary voltage required for a gainclone?
Anthony
Old 24th March 2004, 06:02 PM   #17
BrianGT's Avatar
Anthony
I am using 2x24vac and Peter is using 2x22vac.
The datasheet specifies |-V| + |+V| to be in the range of 20vdc to 84vdc.
(just realized that this is my 2000th post)
Brian
Old 24th March 2004, 06:04 PM   #18
Coulomb's Avatar
I have a spare 750VA 2x30VAC Toroid, I could use that then? 42VDC Rails.
Anthony
Old 24th March 2004, 06:10 PM   #19
Send a message via ICQ to tpenguin Send a message via AIM to tpenguin Send a message via Yahoo to tpenguin
That is what I said about my Aleph projects... and the Cardas posts came in, and are still sitting on the shelf.
I also have piles of heatsinks scattered all over my apartment... (8+8+4+4=24 heatsinks waiting to be used)
...And yet he still won't sell me any of the nice ones. He must be must be saving them for another imaginary project .
Old 24th March 2004, 06:16 PM   #20
Brian
Well, then shouldn't I be able to use the ~30-0-30 transformer I pulled out of that old yamaha? It would certainly be a little close to the limits of the SOA, but I like living on the edge, hehe. In fact, I've run my computer's CPU at over two volts (>25% increase over normal) for overclocking and it survived. It's also a lot more expensive than an LM3875.
Oh yeah, and congratulations on the 2000th post.
Copyright 1999-2017 diyAudio
