Gainclone building thread based on BrianGT's boards - Page 11 - diyAudio
Old 29th March 2004, 03:36 AM   #101
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I didn't really make any direct comparisons between one and two transformers, but it seems to me that two separate add more soundstage. That's how monoblocks "feel" comparing to stereo amp.
One way to have the best of both worlds is to build two stereo amps and use them as monoblocks for biamping each channel. That's what I'm planning on doing.
Old 29th March 2004, 03:50 AM   #102
Illusus is offline Illusus  Canada
Illusus's Avatar
I have been converted to die hard full ranger relatively recently, biamping, although a great idea, will not work in my case. I may at a later point in time add a pair of supertweeters to my speakers, maybe then...
Waht if I built two stereo amps and added a bridging circuit that could be switched out when needed?
Fighting the program since 1976.
Old 29th March 2004, 03:56 AM   #103
More pictures.
The transformer primaries hooked up to the switch/fuse/IEC connector:
The rectifier board connected:
The audio boards mounted on the side panel. Space was tight
Closeup of one audio board:
And finally, everything stuffed inside the enclosure. The wiring's a mess, but the hum/noise is pretty low (inaudible 3' from my 96dB speakers). I tried to keep the power supply wires to one side (left and bottom in the photo) and the audio wires on the other side (top and right).
Alright, that completes my amp and the pictures. Where are the others?
Old 29th March 2004, 04:00 PM   #104
Here's another way to create self contained modules, taking care of attaching the board and power connection. All you need is to attach transformer and inputs/outputs.
Old 29th March 2004, 04:35 PM   #105
Send a message via ICQ to tpenguin Send a message via AIM to tpenguin Send a message via Yahoo to tpenguin
What? Are those Panasonic caps I see on Peter's boards? That is a pretty clever idea, though. Can you come up with something similar using two boards for a modular multi-channel/bridged amp?
Old 29th March 2004, 04:57 PM   #106
Those are Brian's boards not mine. BG don't fit on those
But seriously, this is a module for powered speaker, they wanted cheaper caps.
Besides, those Panasonics sound pretty good.
Old 29th March 2004, 05:07 PM   #107
That is really clever. And quite a contrast with my wiring mess
Old 29th March 2004, 06:25 PM   #108
earsandeyes's Avatar
Default Utrecht (the Neteherlands) late in supply
As I read this thread I do notice that I am not the only one in Utrecht looking foreward to the kit.
THe waiting time does bring beautifull creativity to housing designs. I have a few pages of notepad myself by now, but I do see great ideas.
Did anyone find out what type of linear (displacement) pot/system the original 47labs is using?
I wonder, my DIY experience only restarted recentley with the repair of my CD80, but back in the early eighties you could not find a good word for linear displacement pots.
It could be that they use rotary with a nylon thread or so (Like my first B&O).
On the other hand there are still a lot lin. displ pots used in studio type equipment.
Any guesses or ideas are welcome. It would broaden also my sketching options for housing.
Old 29th March 2004, 07:51 PM   #109
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
ik zit in utrecht en heb ze vandaag gekregen!
Si fractum non sit, noli id reficere!
Old 29th March 2004, 09:19 PM   #110
idex is offline idex  United States
Copyright 1999-2017 diyAudio
