Technics SUV4X  runs cool!
Old 30th June 2017, 11:28 AM   #41
SVI2004A is offline SVI2004A  New Zealand
SVI2004A's Avatar
I have never re capped a V4X yet... unlike a lot of amps, there aren't a lot of caps in this amp only 3 in signal path (2 of them on tone board)
There is a 4th cap on phono board.
- I am somewhat a recap skeptic- lost count of how many times I've read on forums how an amp quit working after a so called re cap... but it's no big job to change the few caps in path.
I remember when amps were amps & speakers were nervous!
Old 12th July 2017, 08:28 AM   #42
ssi is offline ssi  United Kingdom
Hi
Which cap is in the signal path on the v4x that is not on the tone or phono board? Is it the 2200uf cap?
Old 12th July 2017, 08:51 AM   #43
SVI2004A's Avatar
C501 Lch and C502 Rch- 50V 3.3uF
Old 12th July 2017, 11:06 AM   #44
Old 14th July 2017, 08:23 AM   #45
Hi, replaced the C501 Lch and C502 Rch- 50V 3.3uF on my SUV4x without issue. Getting good at using the braid for desoldering now thanks SVI2004. I have improved my technique by using a larger and hotter tip which flows the solder easily through the braid and allows the braid to absorb the solder. The tip I was using before was too small.
The amp sounds a bit sharper but it could just be my imagination! I want my little change to be an improvement!
Another thing.
Do you think it is worth reapplying thermal paste to the SVI2004 chip as these amps are 30 + years old now or would it cause more problems than it is worth disturbing things unnecessarily?
Any thoughts....?
Old 14th July 2017, 10:41 AM   #46
SVI2004A's Avatar
Hiya
No point pulling power ic... I never pull chips out unless necessary. The compound from factory is fine and only needs changing on installation of power ic.
I've never recapped a V4X (except the memory gold caps - done a heap)
Main thing is you're getting the good sound
Most of my V4X amps the power ic has never been touched/resoldered... mostly I resolder q501-4 dry joints and the occasional relay
Old 14th July 2017, 11:25 AM   #47
Thanks - good advice
I just replaced those 2 small caps to develop my skills further.
Old 7th November 2017, 03:31 PM   #48
Hi all
Not used my SUV4x for a bit and got it out recently. Left channel sometimes drops out completely at lower volumes but comes back on if you turn it up. Often happens if cold but has happened after a few hours of use as well. Tried the usual like checking solder joints on the main board including the relay and also the volume control. Not checked the input selector module yet or balance control or speaker selection. Any advice or pointers would be appreciated. Sounds great when working.
Old 11th November 2017, 09:47 AM   #49
Hi all
Found the error. Soldering on main board for the speaker terminals. Reflowed solder and all good. Amp worked fine on headphones which led me to suspect error with speaker terminals.
Best Wishes
Old 11th November 2017, 11:56 AM   #50
New problem. At about 33% volume with a heavy bass thump the amp may be clips and goes silent momentarily (not relay) and then resumes. It is too loud for normal listening anyway at this level but just testing it!. There is no distortion prior to the "clipping". Could it be the main power caps?
Technics SUV4X  runs cool!Hide this!Advertise here!
Runs hot under no use kctess5 Audio Sector 2 1st February 2015 04:52 PM
Technics SL-5210 runs too fast. Search fro Service manual and help Calvin Analogue Source 12 14th January 2012 08:37 AM
Technics suv4x dovi Parts 4 10th August 2007 12:07 PM
OPA4228 runs hot iron25 Solid State 2 1st July 2007 05:42 PM
Technics new class-a amp (runs cold ?) Rixsta Solid State 2 17th March 2005 09:56 PM
