Revisiting an old inverted gainclone - diyAudio
Old 15th April 2017, 06:21 PM   #1
Default Revisiting an old inverted gainclone
I built an inverted gainclone about 12 years ago. It sounded fine at the time although when I first fired it up it was picking up radio somehow. I put a small value ceramic cap from the input to ground and that solved it. I had a 100kdual stereo pot on the back for input gain(voltage divider) and at max it gave some issues. I figured it was the pot being flaky.
I just pulled it out of storage as I need an amp and decided to bypass the pot as I want full gain. Now I get the noise I thought was from a faulty pot all that time. One channel has a high pitched whistle and the other a 60 Hz hum.
I used the uninsulated chips so the rather big heat sink they sit on is sitting at the negative voltage. The wiring is point to point an isn't particularly tidy but the amp seemed fine at lower gain settings prior to bypassing the pot.
Any ideas? Thanks. I haven't been on this site in years. Fun to be reading it again.
Old 16th April 2017, 07:41 AM   #2
If you want help then post your schematic.
It would also help us to help you if you posted some detailed pictures of the assembly.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th April 2017, 05:20 PM   #3
Thanks. I need to remove the heatsink which everything is hiding under to even see what I used for component values.
Old 18th April 2017, 01:55 AM   #4
I gutted it and am starting over. I broke leg off a chip while poking around. So I decided to just junk it. I have two Brian GT boards(I think that is what they are) I will install instead that have been sitting around for a decade. Dual Power supplies and giant 1500VA toroid are still good.Thanks!
Non-Inverted Gainclone Clipping mwl6m Chip Amps 6 25th July 2007 03:34 PM
Inverted GainClone question? 5150ed Chip Amps 35 10th July 2006 08:16 AM
My first non-inverted gainclone circuit eranrund Chip Amps 21 19th June 2005 07:24 AM
PCB for Inverted Gainclone 2Bak Chip Amps 8 19th February 2004 09:09 AM
Non-inverted Gainclone jpask Chip Amps 1 29th March 2003 08:01 AM
Copyright 1999-2017 diyAudio
