TA8210 dual mono amp
Old 11th April 2017, 06:17 PM   #1
slmnklyc is offline slmnklyc  Turkey
Default TA8210 dual mono amp
Hi everyone.
I want to build dual mono(2 ta8210 chip For 2 Channel) amp.
Can anyone give me simple instructions wrt casual single bridged ta8210 amp diagrams on The google?I couldn't manage attaching Photo this post..
My main goal building dual mono classAB 12Vdc amplifier..
Thanks..
Old 13th April 2017, 12:15 AM   #2
MINUX75 is offline MINUX75  France
reed the datasheet TOSHIBA - datasheet pdf this amplifier is already bridged. You have only to mount this amplifier.
Old 13th April 2017, 01:26 PM   #3
^^ I mean this kind of dual mono:
https://www.quasarelectronics.co.uk/...module-ha13118
Old 13th April 2017, 10:03 PM   #4
dddandrew is offline dddandrew  Russian Federation
Hitachi
http://www.bucek.name/pdf/ha13118.pdf
Old 28th April 2017, 06:04 PM   #5
Hi.May I ask a question?
I looked a lot of schamatic For ta8210 stereo.
I think I can use 2chip For 2 Channel.
I COULDN'T SOLVE ONLY ONE THING:
pin1 is mute pin.
Pin4 is standBy pin.
Some diagrams Connect one of THESE PINS to 1led-1 zener diode-1resistor BATTERY STATUS INDICATOR.AND other pin weren't connected to anything.
What happens if I don't use pin1 and pin4?
Why did they Connect The battery-status-indicator To pin1 or pin4?
And how can I Connect The battery status indicator while using 2 ta8210 chip?
Thanks..
Old 30th April 2017, 01:38 PM   #6
I think pin4(standby) default mode is OFF.
I tried to do some calculations.
Can Someone confirm these calculations are Right?
Old 9th June 2017, 03:40 AM   #7
Ok my mistake.pin4 default mode is on.
I solved my problems.Right know I'm trying to add headphone output to this amp.
If you interested to this thread, please share your opinions.
Thanks guys..
TA8210 dual mono ampHide this!Advertise here!
My Dual-Mono 49811 Amp panson_hk Chip Amps 0 13th August 2010 02:37 PM
Use of dual transformer for mono amp jtsaudio Power Supplies 1 20th May 2010 11:51 AM
New-dual mono power amp # 2 Scorpion Solid State 49 12th May 2008 07:41 PM
New dual-mono power amp Scorpion Solid State 34 13th January 2008 07:31 PM
LM3875 Dual mono amp Whitebread Chip Amps 5 26th June 2006 08:16 AM
