Question about these amps... - Page 2 - diyAudio
Old 12th April 2017, 09:10 AM   #11
Originally Posted by cowanaudio View Post
The easiest way to get high quality audio from a PC is to make the most of the............. or HDMI outputs ............
How do we do that?
Is there a cheap way to get analogue audio from an HDMI connection?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th April 2017, 10:13 AM   #12
cowanaudio's Avatar
Originally Posted by AndrewT View Post
How do we do that?
I was using a HDMI to s/pdif audio stripper for many years similar to this one:
HDMI Audio Extractor Converter 4K Switcher-21.07 Online Shopping| GearBest.com
That fed S/PDIF to a DCX2496. It also has RCA outputs.
Don't Procrastinate....Just Do It!
Old 13th April 2017, 05:17 AM   #13
danielwritesbac's Avatar
The easiest way to get high quality audio from a PC is to make the most of the S/PDIF, Toslink or HDMI outputs that are usually available on modern PCs, with an outboard DAC of some description. That's what I've done these last 10 or more years. These three interfaces are all superior to Bluetooth.
I think that this post is almost entirely fantastic!
The exception is the last sentence, and that's because bluetooth is merely wireless that has taken place of a wire or optic fiber--the bluetooth could even use the very same DAC, Power, and Analog devices; so, the inherent difference is notwithstanding. It is also necessary to conclude that no difference is not worth an argument. What is necessary is to recognize that there are several ways to hit the target.
Meanwhile, back to the majority of his post, which is fantastic: An external device could be equipped with a bit of isolation and its own power supply. At that point, opportunity for s/n has been maximized towards goodly signal.
The options that cowanaudio has advised, are available (with optic or isolator), to meet the necessary specs, which is mainly private power so as to divorce the hostile environment of the PC enclosure from the analog signal.
P.S.
After handily circumventing the fidelity foobar of the mono bridged board, which happened to have a sublime power layout, what with the simplicity of utilizing SE mode on the cheap prefab boards (now 2 for stereo) in order to get hi-fi, so expediently and cheaply. . . that was the extent of the convenience, because the next questions would have to be speaker and source of enough quality to keep up with the amp. We'll just have to consider that a nice problem to have.
I think that a bluetooth adaptor matches the price point of two slightly modified amplifier boards, almost seamlessly. However, cowanaudio is correct in his mention of (paraphrased slightly) ANY OUTBOARD AUDIO is worth a spin (more paraphrase) so long as it has its own power supply. Therefore, it is quite clear that bluetooth/wireless qualifies and cowanaudio's advices can also qualify. Indeed, his mention is quite helpful because it gives you more options of quality sources to choose from.
It is necessary to mention the basics again: The goodly source is outboard of the PC and the source has its own power supply.
And, it is also necessary to mention the exceptions: Sometimes it is possible to arrange a favorable PC with a fairly good sound card and the combination will beat all comers. That's a wonderful thing, but it is temporary. Quite likely that either the power supply or motherboard will go out and be replaced. It is NOT the least bit likely that the repaired item will meet your needs for music. DO please start with an outboard source, just as cowanaudio has advised. I would like for that outboard source to have its own power supply. That's because you will be able to retain/keep an outboard source throughout/longer than, several PC changes/replacements. The outboard source plan will be ever so much more satisfactory than having the first PC change cut off your quality.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 13th April 2017, 09:36 AM   #14
i allso have to add that any decent mobo will do close to 100 dBL snr, and that qualifys i think quite nicely for the majority. i see no point in say.. 102 dBL snr, it is an improvement but i don't think i could ever tell them apart.
24 bit /192 khz is pretty standard, considering cd discs have 16 bit and 44.1 Khz , i highly doubt you need more tipically.
so the chips on motherboards are "fine" i guess. problems however occur when a low quality psu is in the system, and the connected "suff" is not really made proper, introducing ground loops.
i can safely say the onboard DACs are well whitin specs, question is the media content, the folllwing stages (amplifier, speaker) and the powersupply.
it never hurts a computer to have a decent PSU anyways so i think that should be out of the problematic questions.
however anything that is isolated and has its own powersupply (that is, it its better than the one in the pc) will give some improvement. even if the improvement is less than what you can ever tell apart.
V*A=VA
V*A*PowerFactor = WATT
Old 13th April 2017, 11:11 AM   #15
cowanaudio's Avatar
My reservations with Bluetooth have more to do with reliability and glitches than outright audio quality. The experiences I've had with Bluetooth so far have never been completely glitch free. I've never had problems with physical digital interconnections, they just work.
Old 13th April 2017, 05:15 PM   #16
well, if you a MAC then certainly you can have some verry dissapointing experience.
not with all of them i guess, however i had no issues with bluetooth on a PC in the past 4 years. just keeps working.
so you may have a point there.
V*A=VA
Old 19th April 2017, 04:55 AM   #17
I mentioned Bluetooth, because it can offer a taste of hi-fi, at a price-point similar to the amp, and even if a phone is the source (plus that usable Onkyo app).
However, I won't object to a better source than that!
In most houses, the better equipment is probably in the same room with the TV and at least another family member is watching that TV, inadvertently guaranteeing that the better equipment never plays music unless it happened to be included on a TV or movie soundtrack.
Application? Instead of piecemeal (mix and match is unpleasant), here's a whole case. . .
SO, instead, let's talk about the kitchen or garage. In most houses those areas don't have desktop computers, chairs or big screen TV's. Therefore it is likely that one could play music in the kitchen or garage.
The old PT-810 bluetooth adapter has specs like a high-end CD player, which is quite basic for today, but importantly doesn't require a lot of bandwidth. The Wi-Fi router might not be able to jam it entirely. If you had required 24 bit /192 khz specs and also have WiFi, then bluetooth is not for you. A multi-simultaneous-channel high-bandwidth Wi-Fi router could even jam the 16 bit / 44.1 Khz PT-810 bluetooth. However, for convenience, I'll say that our case does not include a high-end Wi-Fi router in our kitchen. Perhaps a 150n Wi-Fi router would be okay--those use a single channel.
In our kitchen and/or garage cases, we could use a PT-810, a phone/tablet with the Onkyo app, and a pair of the TDA8932BT mono amplifiers (as well as a pair of speakers). That equipment is assumed for this case.
The TDA8932BT mono boards (that little board with the 5 cap power array and good layout), could offer loud mid-fi if left in BTL mode, or it could offer 1/4 as much watts in hi-fi, if set to SE mode. The latter is useful for this case, because more quality would be the thing to do, and because our kitchen is smaller than an airplane hangar and the speakers are smaller than the fridge.
With the speakers, amplifiers and bluetooth, positioned safely up above the cabinets, the controls (your phone) is then safely in your pants pocket, so that visitors to this nice sounding kitchen can't either tamper the volume or re-set the music to an unpleasant station.
The cost for our kitchen system, with a couple of recycled laptop SMPS, a phone charger, a couple of TDA8932BT mono with filter caps added for SE mode, a PT-810 and pair of secondhand speakers is somewhat $40.
That is a cheap little system! But, price wasn't entirely the point. It is a really cheap little High Fidelity system, with remote.
P.S.
Almost forgot to mention. Even a tame bluetooth can glitch, although it should be rare. That light over the sink? Tap that for the amplifier&bluetooth power in our kitchen music case. Even though the pairing glitch is rare, it still wouldn't be fun to climb the cabinets to power cycle the bluetooth.
question about these 2 amps mikex216 Solid State 1 25th February 2012 02:26 AM
QUESTION ABOUT COMPONENTS ON OLD AMPS mjh7096 Car Audio 2 22nd December 2010 12:58 AM
2 amps better than 1 question? Toast_Master Subwoofers 6 4th December 2007 07:25 AM
Question about Chip amps ElectronicsTech Chip Amps 2 12th September 2004 11:57 PM
Hi-Fi amps....an impedance question rossco Multi-Way 4 25th March 2004 04:26 PM
Copyright 1999-2017 diyAudio
