Old 20th March 2004, 10:56 AM   #1
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Default Switching Power Supply for Gainclone
I'm trying to design a switching power supply for some gainclones. I don't have room in the chassis for an xformer (about 8cm x 10cm x 3cm at a guess) and I don't want a seperate bopx for a PSU. Whilst I was sat with orcad playing around, I thought I might as well ask in case someone else has done one before...
Another thought was an AC wall adapter; has anyone tried one with a Gainclone before?
Thanks,
Gaz
Old 20th March 2004, 11:03 AM   #2
Optical is offline Optical  New Zealand
I am currently investigating modifying a PC power supply, there is an article in silicon chip magazine (october 2003?) on how to modify them to 13.5V, and it gives details on how teh psu's work..
I dont really see what is stopping you making it a higher voltage by winding a few extra turns onto the transformer and using a voltage divider to take the output back to 12V for the voltage sensor if anyone knows what i mean..
i imagine the output caps will need to be replaced with higher voltage low ESR ones too.. but other than that??
these psu's are a dime a dozen, ive got a few now and plan on pulling them to bits this week for a play around..
Old 20th March 2004, 11:39 AM   #3
analog_sa's Avatar
I have listened to computer power supplies in audio circuits and find the resultant sound to be awful. I have also listened to Chord amps powered by smps and they're absolutely divine for solid state. Obviously good sound from smps is possible but likely not easy.
Old 20th March 2004, 11:48 AM   #4
Magura is offline Magura  Denmark
Magura's Avatar
According to Circlotron whos making SMPS's for living, its not worth the trouble. If you can mod a computer supply to fit the bill, then its at least fairly cheap and not too time consuming.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 20th March 2004, 12:34 PM   #5
jackinnj's Avatar
if you do your homework you should be able to put together a switcher without enormous difficulty -- an audio amplifier isn't a job for a computer supply off-line switcher -- they aren't up to the task of handling wide swings in load -- this has been reported on some of the ham radio newsgroups where folks had tried to use switchers for CW (code) -- the response time just isn't great.
delve into some of the manufacturer's application notes -- you will find some good ideas for low noise switching supplies at www.linear.com under the LT1533 and its associated gate drivers (Application Note 70) -- if you are going to use a push-pull topology you can use the "plug-n-chug" spreadhseet linked here: http://www.tech-diy.com/smps.htm
oh, it really helps to have a scope...
Old 21st March 2004, 07:36 AM   #6
Rarkov's Avatar
OK, thanks guys...
I think I'm just going to use bigger heatsinks & a linear PSU
The Gainclone monoblocks will still be tiny though!
Thanks,
Gaz
Old 21st March 2004, 11:29 AM   #7
Colin is offline Colin  United Kingdom
I was also wondering about a switched psu for the Gainclone. Russ Andrews here in the UK is offering switched psu as an upgrade for Naim preamps - but stresses that he had to audition about 30 to find a good one!
Russ Andrews
Not sure if the supply could be adjusted for the GC.
Colin
Old 22nd March 2004, 02:37 AM   #8
What do big PA amps usually use as their psu's?
i always thought those big amps used switching psu's..
there must be some good practicle alternative to using a transformer...
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
Switching Power supply allanon77 Solid State 31 25th June 2010 06:41 AM
K6- Switching power supply microsim444 Power Supplies 3 17th January 2009 12:10 PM
Switching 12V power supply PCB soundNERD Power Supplies 35 27th April 2005 01:35 AM
Switching power supply Thomas B Pass Labs 15 9th December 2002 10:28 PM
Page generated in 0.11154 seconds (63.40% PHP - 36.60% MySQL) with 10 queries
