:: 3d multimedia amplifier ::
Old 19th March 2004, 01:03 PM   #1
dhengkoel is offline dhengkoel  Indonesia
dhengkoel's Avatar
Default :: 3d multimedia amplifier ::
Dear all;
I’ve finished building satellite-subwoofer amplifier for multimedia active speaker. It apply 2 chips TDA 2005, 1 in stereo mode for satellite amplifier, 1 in bridge mode for subwoofer amplifier, 2 transistors for buffer, 1 transistor for subwoofer mixer & filter. But the subwoofer amp make noise: ‘broooommmmm’. I suggest it’s low frequency oscillation.
I attached some pictures. Please give me some suggestion & help.
Regards: ragil.hastomo
:: The last but not least ::
Old 19th March 2004, 01:06 PM   #2
dhengkoel's Avatar
.. the filter ..
Old 19th March 2004, 01:08 PM   #3
dhengkoel's Avatar
.. bottom layer ..
Old 22nd March 2004, 06:42 PM   #4
dhengkoel's Avatar
.. helloooooouuuwwww .. anybody there? ..
Old 22nd March 2004, 08:18 PM   #5
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
do you have the schematic you used to build the amps, as it is rather difficult to tell what you have done simply from a few picturs of the circuit boards.
Old 23rd March 2004, 03:11 AM   #6
soundNERD is offline soundNERD  United States
try disconnecting the input of the sub amp from the transistor output, and short it to ground. turn it on, and see if the hum is there. if it isn't, there is a problem with the transistors. if it is, there is a problem with the amp. check all the soldering and stuff.
-Mike
Old 23rd March 2004, 09:58 AM   #7
palesha is offline palesha  India
TDA 2005A is not good for mains supply operation. It is developed for auto use. It has very poor SVR (Supply Voltage Rejection). Hence put big power supply capacitors.
Old 25th March 2004, 12:43 PM   #8
whats the wattage of that chip? And who makes it?
Old 25th March 2004, 05:18 PM   #9
made by ST. It is 6 watt each channel & 20W when bridged.
Old 26th March 2004, 02:08 AM   #10
well, since that is such low power, why don't you just use higher power chips designed for mains operation (2 x lm1875 or 1 x lm1876 for the tweeters/midranges, and something like a 3886 for sub?
:: 3d multimedia amplifier ::Hide this!Advertise here!
IK Multimedia Support IK_Support Introductions 3 17th October 2008 06:26 AM
Win 98 multimedia properties jmar Digital Source 0 12th February 2004 11:01 PM
Multimedia Speaker Jeehemdee Everything Else 1 7th December 2001 03:30 AM
Multimedia System Super Multi-Way 0 13th July 2001 02:04 AM
Copyright ©1999-2017 diyAudio
