Old 19th March 2004, 12:54 AM   #1
Kofi Annan's Avatar
Default Voltage When Switch is Off
This is a total newbie question, but...
Today I was rewiring my Gainclone (aka "Ghettclone"-- worst wiring job EVER) when I thought I had blown a crappy Radio Shack switch and it was failing OPEN!
After futher review (and the purchase of a few more switches) I found that the cause is apparently NOT the switch. When I have the switch on, the voltage across the rectifier diodes is about 17.5 (about what it should be), when I turn the switch OFF, the voltage drops BUT DOES NOT GO AWAY!
I have measured the voltage across the rectifiers at anywhere from 2 volts to 10 volts.
I know that this may seem an idealistic newbie vewpoint, but I thought OFF meant OFF! When I unplug the power completely, the voltage drops to zero.
Is it possible that I have not properly grounded the power supply (I'm testing this) or that I there's a cold joint on the wiring for the neutral / return for the AC?
Maybe I'll just take up knitting, like Mrs. Annan.
Please help!
Kofi
Old 19th March 2004, 12:59 AM   #2
Bryan is offline Bryan  United States
This may seem like a stupid question, but are you sure your switch is on the live wire of the mains, and not the neutral?
Just a thought???
Dont take life too seriously, you will never get out alive!
Old 19th March 2004, 01:01 AM   #3
tja is offline tja  Netherlands
Caps?
Old 19th March 2004, 01:03 AM   #4
Magura is offline Magura  Denmark
Magura's Avatar
Dosnt it sound more like he is seeing the voltage of the psu caps?? Else he would measure the same voltage all the time if it was the 0 wire he had the switch on??
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 19th March 2004, 01:32 AM   #5
Kofi Annan's Avatar
Actually, the answer is no to both questions.
The switch is connected to the live wire and there are no ps caps attached yet. By the way, there are no stupid responses-- only stupid questions, like mine.
After I re-grounded (is this a word?) the power supply, the voltage on the rectifier diodes with the switch OFF is steady at about 2.5 volts. Not enough to kill (probably), but enough to **** me off.
Any other thoughts? I would happily engage in Santaria if I thought it would go away as a result.
Kofi
Old 19th March 2004, 01:34 AM   #6
Kofi Annan's Avatar
Wow. I've never been censored before. I'll have to bring this up at the next UN poliy meeting.
For those scratching their heads, the four letter word I used is common North American vernacular pertaining to the excretion of liquid from one's engorged bladder.
Kofi
Old 19th March 2004, 01:56 AM   #7
Magura's Avatar
Have you measured the potential between zero and ground without the amp connected ??
Magura?
Old 19th March 2004, 02:17 AM   #8
Me thinks Magura has a point - check your voltages - things may be rotten in Denmark!
Were you really born on Friday?
Steve
Old 19th March 2004, 02:19 AM   #9
Kofi Annan's Avatar
I guess you're talking about measuring the voltage between the neutral plug and the earth ground plug on the AC receptacle?
If so, there's nothing with the ps unplugged, but about 25V AC with the ps plugged in and aobut 47V AC with it plugged in and switched on. No ps caps here and no amp circuit connected-- just the grounded power supply and some moron who put it all together.
Kofi
Old 19th March 2004, 02:23 AM   #10
Magura's Avatar
This requires a picture and a schematic to solve
Magura
Gate-source voltage needed to switch a FET rtarbell Power Supplies 9 9th January 2007 10:27 AM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Main on/off switch for amp using a piezo switch using_e Solid State 13 20th June 2006 05:55 PM
Voltage level switch JDeV Everything Else 5 4th July 2003 10:06 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Page generated in 0.11786 seconds (74.54% PHP - 25.46% MySQL) with 10 queries
