Protecting speakers against dc with mute?
Old 17th March 2004, 01:42 AM   #1
soundNERD is offline soundNERD  United States
Default Protecting speakers against dc with mute?
Heres what I want to do:
I have an LM3886 amplifier, but am worried about DC on the speaker in case something goes wrong with the input resistor or something else goes wrong. Can I make the mute mode activate the second there is DC on the output?
Thanks,
Mike
Old 17th March 2004, 07:05 AM   #2
djk is offline djk
djk's Avatar
"Can I make the mute mode activate the second there is DC on the output?"
And this would do what?
This is a crowbar:
http://www.diyvideo.com/forums/attac...p?postid=49718
If the amplifier is FUBAR the mute circuit or the SPIKE circuit will not protect the speaker.
If you did something to cause the DC that you can correct, the SPIKE circuit in the chip will protect it from the crowbar.
Old 17th March 2004, 07:34 AM   #3
StratoFan is offline StratoFan  Hungary
StratoFan's Avatar
Send a message via ICQ to StratoFan Send a message via AIM to StratoFan Send a message via MSN to StratoFan Send a message via Yahoo to StratoFan
Default Re: Protecting speakers against dc with mute?
Thanks,
Mike
Try out UPC1237. This is a simple speaker protection circuit.
http://www.promelec.ru/pdf/upc1237ha.pdf
Old 17th March 2004, 08:18 AM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Thanks,
Mike
You don't have to worry about the input resistor. I think your fears are unfounded as long as you have done the LM3886 connection right.
If you have a 500 W amp with discrete parts I thinks it's more need for DC-protection.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 17th March 2004, 11:41 AM   #5
No, about the input connection, The resistor to ground is soldered across the end of the input wires, not the board. So, if the wire would break, then the input is floating, and the output on the speaker goes to about 20V. So, when that happens (which it has) I want the mute to flip on to protect the speaker. I know if the amp fails, then the mute pin wouldn't stop the DC, but that I am not worried about.
Actually, if the speaker has a fuse, will it blow if there was any large voltage on the speaker?
Old 17th March 2004, 03:49 PM   #6
lgreen is offline lgreen  United States
lgreen's Avatar
Default Mute circuit
How about this, connect a relay between the mute pin on LM3886 and the negative supply and activate the relay (to open it) whenever you have a lot of DC show up on the output, like 20V.
Use a relay activated by a high voltage (12-20V) and just connect the ouput to this relay The relay will certainly be activated by 20V, just make sure in normal operation you don't exceed the relay activation voltage. I suppose you could drop the voltage with a resistor to use a more sensitive relay. Now resetting the relay may be interesting but if you choose the right type of relay it may reset itself when the voltage goes below the "set" threshold.
Old 17th March 2004, 08:42 PM   #7
ok i am lost, how do i connect it again?
Old 17th March 2004, 09:30 PM   #8
peranders's Avatar
First, why should the wire break? I assume that your amp looks tidy inside. It's not very good the either of the inputs float but see to it that this never happens. If you are worried about this pulldown resistor I'd suggest that you connect it closer to the IC. My advice to you is to make good connections everywhere. The LM38xx is very safe and hard to destroy _if_ it's connected properly.
If would probably not protect for harmful DC
Old 20th March 2004, 11:41 PM   #9
djk is offline djk
djk's Avatar
"If would probably not protect for harmful DC "
I've replaced enough relays with welded contacts to know that they can't protect against DC either.
Good commercial PA amplifiers have both a relay for quiet on-off use, and a crowbar for protection.
Old 21st March 2004, 12:00 AM   #10
Christer is offline Christer  Sweden
Interesting point, should we understand that as the relays have
been "welded" during normal use (delayed turn on etc.)
so they don't work when eventually needed for protection?
Protecting speakers against dc with mute?Hide this!Advertise here!
Protecting a microcontroller rtarbell Parts 10 11th January 2008 01:23 AM
why is my amp protecting? mbugua Class D 2 19th January 2007 12:58 PM
protecting mosfets in UcD zilog Class D 10 12th November 2006 07:52 PM
protecting my speakers from my GC damitamit Chip Amps 13 16th June 2003 03:46 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 10:54 AM
Copyright ©1999-2017 diyAudio
