My first amp & its blown (need help)
Hello guys, greetings from jakarta, i found this scheme in net, i build it EXACTLY same with the scheme, im using 33-0-33 unregulated psu with 6x 4700uf, and the amps not working, the right (negative) elco always blown up, pls correct me, its frustated
Best.
Bobby
Only two possibilities (well three actually)
1/ The caps are not what they seem (fake) and can not stand the voltage.
2/ They are fitted wrong way around.
3/ And finally they would blow up if you are applying AC and not DC to the board.
where did you find room for six caps on a board that only has space for four?
saying you built it just like like the "scheme" would make you a liar...
is "elco" supposed to mean electrolytic as in capacitor?
things can't get frustrated but people can...
Im using regular parts, only that i can get in my local store, I only give them 50% of their limit (write on their body), i think something wrong in the layout, but i dont know what, im newbie at this
Best.
Bobby
That last picture shows the cap releasing the magic smoke.
BPS. The first thing to do is to wire it to a bulb tester to prevent any sudden explosions.
Looking at your first picture in post #1 and the later pictures and I would say the caps look to be fitted correctly.
You need to disconnect the amp from the power supply board, and then measure the DC voltages on the power board. Make sure you discharge the caps before connecting the amp back up
Will use the bulb tester, thanks for your advice sir
I always discharge them with R before connect or disconnect amps with psu, my meter says 33,5-0-33,5 at vdc, im using 24-0-24 vac with my ugly transformator
no you would use enameled wire and wrap it around the resistor to produce a 7 micro henry inductor to create a low pass.
the physical size of the resistor is important so the wattage rating could well be 2 watt or greater that's why i was hoping to see the "schematic"
english is not my mother tongue so no worries, but being clear is important...
Before you next power it up you could solder a couple of wires to the caps that blow, and then connect these wires direct to your meter. Make sure you get the meter polarity correct and set the meter to the correct range.
Then when you switch on you will see in an instant if the voltage is reversed.
what the H, E, double hockey sticks is "cmiiw"?
are "transformators robotators in disguise" 😀
It is "correct me if im wrong"
Again, english is not my language, believe me I do my best here, and you are not so helping btw
Will do sir, should i make it down to 25vdc ?? I have 18vac output in my "transformer". I have plenty of 24 regulator ic here
The resistor should be wrapped like this
10 Ohm 2w resistor with 10 to 12 turns of 22ga insulated wire
and did you install the jumper wire between the 22k and 1k resistors?
I install the jumper sir, will make the L now, thanks for the tutor 😀
well i apologize i did not intend to offend you in any way, sorry. as someone who has had to overcome language barriers myself i guess my misguided attempt at some lighthearted humor is out of place, once again, sorry.
sincerely hope you can resolve your troubles.
p.s. i don't think internet acronyms are an effective or helpful means of communication as there is no accepted standard for them.
