| Chip Amps Amplifiers based on integrated circuits |
#21 | ||
But.............. Quote:
#22 | |
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#23 |
diyAudio Moderator Emeritus
I have a reel of 1% metal film resistors sitting here, and while the resistors aren't 0.1% of the intended value, they are generally less than 0.1% of each other, for the random samples that I took, sequentially on the reel. My resistors in the 5% reel are also quite close to each other.
I am using a fairly accurate fluke multimeter. -- Brian |
#24 |
I've got may spare LM2875 it might be good to use them for a high power amp for AV system.
After reading & apply all comments above in condition that using all 1% res, how about this one? |
| need advise: 3-channel tripath with 12V power supply | smoerk | Class D | 7 | 17th August 2007 03:06 PM |
| Is a bridge / parallel configuration of 3875 is better for my speaker ? | 100db | Chip Amps | 7 | 8th March 2006 10:42 AM |
| I need advise for three channel Parallel LM4780 project. | Padel | Chip Amps | 8 | 21st November 2005 11:27 PM |
| Parallel 3875 or single 3886 for low impedance speakers? | Groucho2004 | Chip Amps | 2 | 17th July 2004 08:31 PM |
| ==>> Parallel 4x LM3875 for 2 ohm speaker - pls advise.. | metha | Chip Amps | 24 | 18th April 2004 08:29 PM |
| Page generated in 0.14595 seconds (45.88% PHP - 54.12% MySQL) with 11 queries |
